Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
Unread 01-01-2007, 13:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Threaded rod through ball bearings
that's a good point...although from the drawing, it's kind of difficult to figure out just what all the parts are, and how everything is supposed to be held together.
also it's not very difficult to use a die to put threads on the end of a round steel rod, rather than using threaded rod. One could even buy a long bolt, which has threads only on the last inch, cut the head off, and thread the cut off end with a die.
Rod-Less Cylider??? sgsdragons Pneumatics 4 24-01-2005 19:55
threaded rod Mercutio OCCRA 3 28-09-2003 20:45
Drills: The ball bearings are gone? BobbyG Motors 0 21-01-2003 23:57
threaded rod fasteners... archiver 2001 1 24-06-2002 00:08
threaded rod? RobDeCotiis Kit & Additional Hardware 4 18-02-2002 12:21
