Go to Post changing some 0 to 1s was a lot lighter and cheaper than most of the clutches I found. - IKE [more]
Unread 01-01-2007, 15:42
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Threaded rod through ball bearings
Originally Posted by squirrel View Post
just curious, have you calculated the maximum torque on the rod? low grade 3/8" hardware usually breaks at about 40 ft lbs or so.
It's geared for about 57 ft*lbf of torque at stall.
Also, there'll be a tensioning mechanism that occupies the space inside the tubing, enveloping both the bolts and the shaft. This'll
Originally Posted by Dick Linn View Post
It looks like you are going to depend on the nuts being very tight, rather than having keyways or a hex shaft or pins to keep the wheel and the sprocket from loosening and spinning with respect to each other.
I suppose that's one way of describing it. I'm relying on the coupling nuts' inability to move along the thread -- that is, to tighten or loosen -- to drive the shaft. I'd just as soon use hex shaft as this ridiculous scheme if I could decipher some way of sticking a hexagon into a small round hole. It assumes that it's easier to drive the robot than it is to strip the threads -- which may not be at all true.
This is an (over?)extension of a method that was used to drive FIRST robots years ago. The 2003 KoP included an adapter that threaded onto the Bosch drill output and was secured in place by a left-handed screw. The adapter accepted a 5/8" dia. keyed shaft on the other end, so maybe that's my clue that what I'm trying to do here is a bit stupid.
I'm a terrible machinist and usually the person responsible for explaining to students and mentors alike what processes they need to follow to make the parts I design. If I don't know how to make something, nobody does; so I often stick to what I'm most comfortable with.
I appreciate everyone's help a lot. I'm a bit dense sometimes and don't always think things through until long after I've invested myself in making them work.
--Madison--
...down at the Ozdust!
Rod-Less Cylider??? sgsdragons Pneumatics 4 24-01-2005 19:55
threaded rod Mercutio OCCRA 3 28-09-2003 20:45
Drills: The ball bearings are gone? BobbyG Motors 0 21-01-2003 23:57
threaded rod fasteners... archiver 2001 1 24-06-2002 00:08
threaded rod? RobDeCotiis Kit & Additional Hardware 4 18-02-2002 12:21
