Go to Post The fact that it is easy doesn't mean that it is smart. - JVN [more]
Unread 01-01-2007, 17:20
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Threaded rod through ball bearings
Originally Posted by Dick Linn View Post
Is there any way to upgrade the design to a 1/2" or 5/8" shaft? Something with enough meat in it to allow pinning or a shaft key or just more torque in general? I can remember using an adapter off the old drill transmission to couple a shaft. However, that was before the final stage of gear reduction, and hence subject to a lot less torque.
We don't have broaches or an arbor press, so I try to avoid keyed shafts whenever I can. If it comes to that, we'll just use dead axles again in 2007 as we've done for the last several years.
Edited to add: I've been poking around the 'net for a few hours trying to see what I could find about calculating the torque required to strip a nut or bolt of its threads. I've come across some things suggesting good practice -- that the bolt shaft should fail before the thread strips -- but nothing explicitly offering an answer to the question. I understand that the answer is a function of the nut and bolt material and the shear area. The shear area is, in turn, a function of the number of threads engaged between the nut and bolt. Beyond that, I think that my brain is fried and I'm missing a connection somewhere that'd let me equate the output torque of my gearbox to the force required for the coupling nut to strip the threads on the shaft.
--Madison--
...down at the Ozdust!
Rod-Less Cylider??? sgsdragons Pneumatics 4 24-01-2005 19:55
threaded rod Mercutio OCCRA 3 28-09-2003 20:45
Drills: The ball bearings are gone? BobbyG Motors 0 21-01-2003 23:57
threaded rod fasteners... archiver 2001 1 24-06-2002 00:08
threaded rod? RobDeCotiis Kit & Additional Hardware 4 18-02-2002 12:21
