Go to Post Dean Kamen, you deserve a cookie. - Jessica Boucher [more]
Unread 02-01-2007, 09:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: 6WD Module
Originally Posted by Cody C View Post
Madison,
As Andrew said, We have been developing a similar drive train, but are wondering how much each of your modules will weigh completed. As is, A completed frame with our currently designed module will weigh about 35-40 lbs, with each module weighing 15 -20 lbs. Is this comparable to yours?
Also, our current design differs from yours in that we will attach the modules directly together using aluminum tube, and that will form our primary Frame. Because of this, our modules had to be somewhat more... Robust, and are going to be made of a thicker plate, probably .20-.25 inch. As soon as we have some renderings we will post them, and thanks for your help in advance
-Cody C
That sounds pretty close to the weight calculated by Solidworks. My model is missing bolts, chain and little things like that and comes in at about 10 lbs. per module and 25 lbs. for the whole chassis.
I was planning on seating this design inside a frame of 3x1" aluminum channel, somehow using the spacers and bolts on each end in the scheme to attach it to the frame. I didn't develop it much further than that because I began in on yet another 6WD setup that's integrated wholly into the frame.
I'm looking forward to seeing your renderings. I'll likely be putting up some new renderings of the latest 6WD arrangement we've designed later today.
--Madison--
...down at the Ozdust!
pic: Completed Mecanum Module Madison Technical Discussion 9 12-11-2006 19:39
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
6WD? Alex Cormier FIRST Tech Challenge 14 17-04-2006 22:10
pic: 494 Power Module KEY Extra Discussion 14 26-01-2005 17:50
pic: Tytus's Coax Crab Module CD47-Bot Robot Showcase 8 17-11-2003 10:08
