Re: Urgent problem, probably with Inventor 11 install.
Autodesk support has a page on this error in older versions of Inventor. I can't say if your problem is the same, but it sounds like there might be a program registry issue.
Do you have both 10 and 11 installed? If 11 was installed and you try to run 10, it will most likely need to re-register the paths for 10 in the Windows Registry. I believe that you have to have at least Power User privileges for it to do this, however. I run both versions and have regular User privileges at work and have to have an admin run the program each time I switch (gotta love Sarbanes-Oxley!). |
| urgent projector problem | sirbleedsalot | IT / Communications | 9 | 10-04-2005 02:54 |
| Urgent!!! Problem concerning Backup battery and autonomous. | Code\\Pilot | Programming | 3 | 26-02-2004 16:44 |
| HELP! Problem with General Dimension in Inventor 5. | sanddrag | Inventor | 12 | 21-09-2003 21:46 |
