Go to Post No! I will not be an enabler for this madness. Go outside. See a movie. Read a book. LIVE!!!! - Herodotus [more]
Unread 02-01-2007, 08:52
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Urgent problem, probably with Inventor 11 install.
Over our winter break, the IT guys at our school came in to install Inventor 11 to the computers here. Inventor 10 worked fine before we left, and we were all looking forward to our upgraded design accelerators among other things. However, much to my dismay, I came in to the room for my first period class, hoping to use Inventor 11, when I found that 10 was still installed. I figured that the IT guys just didn't come in to fix it, but now whenever I try to open 10, it comes up with this message.
Does anyone know what the problem is?
EDIT: Sorry for the link to the image, but I didn't want to post a huge image here and stretch the page all over the place.
EDIT 2: Looks like the problem was fixed. Thanks for helping.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 02-01-2007, 12:21
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Urgent problem, probably with Inventor 11 install.
Autodesk support has a page on this error in older versions of Inventor. I can't say if your problem is the same, but it sounds like there might be a program registry issue.
Do you have both 10 and 11 installed? If 11 was installed and you try to run 10, it will most likely need to re-register the paths for 10 in the Windows Registry. I believe that you have to have at least Power User privileges for it to do this, however. I run both versions and have regular User privileges at work and have to have an admin run the program each time I switch (gotta love Sarbanes-Oxley!).
Pete Kieselbach
Unread 02-01-2007, 16:11
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
The Inventor 11 readme notes:
If Autodesk Inventor 11 & Autodesk Inventor 10 are installed and used on the same machine, make sure that Autodesk Inventor 10 has SP2 or greater applied.
But I don't know if it would cause more problems if service packs are applied to Inv10 after 11 is already installed.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 02-01-2007, 22:01
The computers with errors don't have 11 installed.
That might be the problem. I'll try that tomorrow. Thanks .
Unread 03-01-2007, 07:43
It appears that having Inventor 10 on the computers was the problem. I guess the IT guys took care of it last night. Thanks for all your help.
urgent projector problem sirbleedsalot IT / Communications 9 10-04-2005 02:54
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
HELP! Problem with General Dimension in Inventor 5. sanddrag Inventor 12 21-09-2003 21:46
