Go to Post Taking the time to do it right the first time is faster than rushing through it a third time. - EricVanWyk [more]
Unread 02-01-2007, 16:14
razer razer is offline
FRC #1690
razer is an unknown quantity at this point
Hi, I need some help with the MPLAB IDE...
Hello,
Here is my problem:
Everytime I try to Build my project (to hex file) I have the next error:
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - Coff file 'AARG.O' does not appear to be a valid COFF file.
Error - Could not build member 'AARG.O' in library file './clib.lib'.
Errors : 2
BUILD FAILED: Tue Jan 02 23:04:19 2007 ".
I dont know how to solve this problem, because in my school I dont have this problem, and I use the same code. Even when I use Default Code, it doesnt work at my home.
Im new to the FIRST competition, so i dont know the MPLAB well yet, so anyone can help me here..?
Thanks.. A lot.
To contact me through email: nbtk123@gmail.com,
MSN: razer@hotmail.co.il
Unread 02-01-2007, 16:18
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Hi, I need some help with the MPLAB IDE...
Wow, weird. It's trying to pass a .O file to the COFF reader? Hmm...try a clean build--delete all .O files from the directory and try again. After that, if it was me, I'd re-install MPLAB.
That's the strangest thing I've seen yet...
JBot
Aren't signatures a bit outdated?
Unread 02-01-2007, 16:22
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Are you sure you are using version 2.4 of mcc18? I think that might be the issue.
Unread 02-01-2007, 17:01
I'll backup Chris on his answer.
That error message indicates that at home you are using a Microchip compiler later than the c18 v2.4 we are using for FIRST. You must use the same compiler version you have at school. It was sent to your team on a CD in the Kit-Of-Parts.
You cannot use the latest version of the Microchip compiler, because it is incompatible with the ifi libraries compiled under the older v2.4.
Unread 03-01-2007, 01:53
FRC #1690
Maybe.. Because at school I have MPLAB IDE 7.20, and at home its 7.30.
I had a problem with my C18 Compiler so I took the compiler from school (on a flash disk) and I put it at home.
At school i use code v2.2, and at home too... Do you think that my problem is different versions...? at school i could load a 2.4 code with MPLAB IDE 7.20...
thanks
Unread 03-01-2007, 02:12
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
thanks
You're referring to the version of the IDE, which is just the nice interface. You need to worry about the compiler, which is version 2.4 or 3.x. The 3.x won't work with FIRST code, and seems to be the version you have at home. The 2.4 version is what you have at school, and does work with FIRST code.
You'll need either the original installation disk or to copy the c:\mcc18 directory (that's the install location, by default, of the MPLAB C18 compiler).
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 03-01-2007, 08:21
The error message you saw means the the compiler version you're running at home (copied from school) isn't the same version as the libraries you're pulling in from mcc18/lib.
Could be because you didn't take the whole mcc18 directory from school as Cjmovie suggested, or could be because MPLAB is pointing to parts of your original home C18 directory or your original C18 compiler.
To check the latter:
-- look in MPLAB under Project->Build Options->Project and see if the directory paths listed there point to the correct C18 version.
-- look in MPLAB under Project -> Select Language Toolsuite to see if each of the directory paths for every tool is where it should be.
Unread 03-01-2007, 11:06
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I believe you get download a student version of C18 complier v2.4 from www.microchip.com, but i haven't looked for it. You just need to make sure that is is v2.4.
Eric Haskins KC9JVH
Unread 04-01-2007, 06:47
FRC #1690
OK I started everything from the beginning...
I removed my MPLAB 7.20
and the C18 too.
Then I downloaded & istalled the MPLAB 7.20 & MPLAB C18 from this link:
https://jvex-robotics.dev.java.net/ToolChainSetup.html
it works now, but something is weird:
When I installed it on D drive it didnt work, It says that it couldnt find the file clib.lib... But now it's installed on C drive it wroks... anybody knows the reason?
thanks a lot... now im OK
Unread 04-01-2007, 07:47
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
As Mark said above you would have to direct MPLAB to look for the C18 header files in a different location not the default c:\mcc18
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
need some help with the OI, and wiring a display pryoplasm Control System 8 10-03-2004 20:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
I need some help with scouting archiver 2001 18 24-06-2002 01:28
