Re: pic: FRC488 - Six Wheel Drive Chassis
Can you explain why you chose not to have a cross brace? I'm not a mech-e but I would guess you need one.
Because the center wheel is not lowered at all, at least one outside set of wheels should be omniwheels to alleviate friction while turning. I chose to put a set on each end because there's no penalty to in line pushing force, generally, and I like to subtley encourage our drivers to avoid conflict. ![]() Quote:
The omniwheels are riding on 5/8" keyed shaft, while the AndyMark performance wheel is broached for a 1/2" hex shaft. It'd be relatively easy to change out a set of omniwheels for a set of traction wheels with a little bit of forethought. Namely, I'd need to make some shafts that are 5/8" diameter with keyway on one end and 1/2" hex on the other. I'm waiting on the game before adding cross-bracing since I'm not sure if I'll need a scoop or something on one or both ends. I'd like to, if weight allows, put an aluminum plate (1/16" or so) across the bottom to add rigidity. |
I noticed that the front and rear c channels are notched for the drive rails on top and bottom. This could be a weak point. Shouldn't the drive rails fit inside the c channel leaving the channel uncut ?
M -
Looks quite nice, and you have obviously put a lot of work and thought into the design. The efforts to minimize the total weight are obvious. The biggest concern you may have is strength in the event of an impact or collision. You might consider making the frame members out of rectangular tube instead of channel. Given the amount of material you are removing, the additional weight from the fourth side of the tube will be minimal, but there will a considerable increase in stiffness of the frame assembly. Just out of curiosity, what is the spacing between the wheel sets? Is it sufficient to cross a 20-inch wide, 16-inch deep, water-filled moat, should that capability ever be necessary? -dave Last edited by dlavery : 03-01-2007 at 00:03. |
Oh goodness.
#7
Here we go again...
#8
Any crocs? CRIKEY! |
#10
WATCH OUT!!! WE'VE GOT A DAVE ON THE LOOSE!!! SOS...SOS...SOS
#11
That looks very nice and pretty well engineered. My suggestions are that you only use one set of omni wheels. You have to admit that you will be getting in to conflict no matter what you do.
The frame does look pretty sound, but with all that material taken out, are you worried about bending at all? these bots go through some pretty hard hits. But i am very impressed by your design and i look forward to seeing the end product after the next hectic 6 weeks =) --Dan |
#12
I love the simple approach to the 6-wheel drive. I'll be follwing up later if you use this to see what additional stiffening was used/needed. Good luck. |
#13
Because of the holidays primarly, we haven't really done much of anything with our mecanum drive prototype. It still has no feedback system installed and remains difficult to drive. Most of the team agrees that, unless it appears to be a perfect solution for the new game, we'll stick with something more traditional like this drive, so there's a good chance you'll be seeing it somewhere. |
#14
Madison, I know that you have no broach capability, so I'm curious- where do you buy your #25 sprockets? I can't find any finished ones online, or in the Browning catalog.
#15
For this, we'll be ordering from McMaster-Carr -- part no. 2737T123. 5/8" bore was the smallest I found with a keyway for this particular sprocket. I didn't take a comprehensive look at many teeth counts, though, so I'm not sure how consistent the keyways are in 5/8" bore sprockets -- but I can't imagine why they all don't have one.
| pic: 4 Wheel Strafing Chassis | Holtzman | Extra Discussion | 9 | 08-07-2009 19:28 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| pic: Omni Wheel Drive -- Top | Richard Wallace | Extra Discussion | 4 | 05-12-2005 18:55 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| pic: 6 wheel drive train pick | CD47-Bot | Robot Showcase | 3 | 14-04-2004 07:10 |
