Go to Post To anyone who is discouraged about their team, don't let yourself get down. I've seen my team go from having a robot that barely moved (and I'm not kidding, we had keys falling out of gearboxes) to this year with a robot that is ACTUALLY GOING TO WORK. Don't lose hope, stick with FIRST! - ZipTie3182 [more]
Unread 02-01-2007, 13:48
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Encoder Problem
I am using four grayhill encoders for our robot that uses a mecanum drive system. I am using the frc_encoder code from kevin watson. When I download the code unmodified it works just fine and all the encoders give me a reading. When I copy and paste the mecanum drive code into the encoder code only one of the encoders gives me a reading. Any help is much appreciated.
Unread 02-01-2007, 13:52
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Encoder Problem
Can you post the code that doesn't work?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 02-01-2007, 16:07
Re: Encoder Problem
Attached to this message is the user routines file that doesn't work.
Unread 02-01-2007, 16:19
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Encoder Problem
At a quick glance I dont see anything wrong. To confirm, your sayng when you comment out/dont run Default_Routine() that all 4 encoders work but when you run it only 1 does?
Re: Encoder Problem
The "\r\n" part of your printf commands bothers me. Aren't we supposed to use just "\r" and not "\n"?
How does this code differ from what does work?
Unread 02-01-2007, 16:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Encoder Problem
It's a carriage return and a line feed. He's constructed it like a Windows text file, which would normally use that escape sequence to mark a new line.
Unread 02-01-2007, 18:40
Re: Encoder Problem
I have tried commenting out the calll to default routine but it still only will read one encoder. The only difference between my code and the frc_encoder code ist that I have added some mecanum drive code for our robot.
Unread 02-01-2007, 18:53
Team 2021 Captain
AKA: Chris Davidson
Re: Encoder Problem
Could you please post both copies of your code for us to look at.
Unread 02-01-2007, 19:56
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Encoder Problem
Did you add code any where else besides user_routines?
Unread 02-01-2007, 22:53
Re: Encoder Problem
The new user routines is the one from my earlier post and the old user routines is attached to this message and the only thing i edited between the two codes is the addition of the mecanum drive code.
Unread 02-01-2007, 23:13
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Re: Encoder Problem
Have you tried putting in the frc_encoders code again to see if all the encoders still work?
Unread 03-01-2007, 08:30
Re: Encoder Problem
When I download the frc_encoders the encoders work great but when I add the mecanum drive code only one encoder will feed back values.
Unread 03-01-2007, 08:44
Team 2021 Captain
AKA: Chris Davidson
Re: Encoder Problem
Try running the 2 through a diff tool to see the difrences in the 2 files. I didnt see anything when I did a quick look, ill check again when I have more time.
Unread 03-01-2007, 08:54
Re: Encoder Problem
Where would I get a diff tool. I've never even heard of such a thing.
Unread 03-01-2007, 09:04
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Encoder Problem
Not so:
From code that works:
/* SECOND: Set up the I/O pins you want to use as digital OUTPUTS. */
digital_io_17 = OUTPUT; /* Example - Not used in Default Code. */
/* THIRD: Initialize the values on the digital outputs. */
rc_dig_out17 = 0;
From modified code:
digital_io_17 = INPUT; /* Example - Not used in Default Code. */
Encoder Pinout bear24rw Electrical 4 04-12-2006 21:43
Encoder help Windward Programming 21 14-01-2006 15:10
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
