Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Unread 02-01-2007, 22:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
pic: FRC488 - Six Wheel Drive Chassis
Unread 02-01-2007, 22:06
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: pic: FRC488 - Six Wheel Drive Chassis
A couple of questions:
Does that have any rocker in it? And is that 25 or 35 chain?
Unread 02-01-2007, 22:28
Joel J's Avatar
Joel J Joel J is offline
do you..
Why omniwheels on a 6WD?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 02-01-2007, 22:30
EricH EricH is online now
Turning, I'd say. Instead of lowering the center wheel, why not use omni's? It's more stable and more maneuverable. (It's also easier to spin around by hitting.)
Unread 02-01-2007, 22:31
Gdeaver Gdeaver is offline
FRC #1640
If the bumpers are back and the design is like 2006, then the next step is to add mounting to this frame that would allow the bumpers to be a structural element. If the rules allow forget home center plywood. Baltic birch "wood" be a good choice.
Unread 02-01-2007, 22:32
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Not necessarily more maneuverable, But I bet it is nice to have the 'bot spin around it's center set of wheels instead of whichever four happen to be touching the ground
Unread 02-01-2007, 22:38
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Wow, looks light! Do you have an estimated weight for the entire drive base?
And on the subject of omniwheels: It looks like with the setup you have it would be very easy to swap them for traction wheels if they are needed. I guess that would be decided in testing.
Unread 02-01-2007, 23:07
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Can you explain why you chose not to have a cross brace? I'm not a mech-e but I would guess you need one.
Unread 02-01-2007, 23:24
Madison's Avatar
FRC #0488 (Xbot)
The wheels are all in line -- there's no 'rock' at all. The chain is #25.
Because the center wheel is not lowered at all, at least one outside set of wheels should be omniwheels to alleviate friction while turning. I chose to put a set on each end because there's no penalty to in line pushing force, generally, and I like to subtley encourage our drivers to avoid conflict.
I'm now looking at a mounting scheme that will accept bumpers and protect the wheels from impact. I've never put bumpers on a robot before, so I'm looking at examples of others' work to get an idea how to best accomodate the additional weight of the bumper assembly.
Our 2005 robot had a lowered center wheel and the tipping action drove me and our drivers crazy. It's an impact to the system each time the robot's inertia shifts and that starts to lead to annoying things like loosened bolts and the like. Practically, it's cheaper and easier for me to make omniwheels than it is to make traction wheels and it's certainly cheaper than buying them.
As shown -- which includes everything but stiffening gussets and a base upon which to mount electronics, it's 29.5 lbs.
The omniwheels are riding on 5/8" keyed shaft, while the AndyMark performance wheel is broached for a 1/2" hex shaft. It'd be relatively easy to change out a set of omniwheels for a set of traction wheels with a little bit of forethought. Namely, I'd need to make some shafts that are 5/8" diameter with keyway on one end and 1/2" hex on the other.
I'm waiting on the game before adding cross-bracing since I'm not sure if I'll need a scoop or something on one or both ends. I'd like to, if weight allows, put an aluminum plate (1/16" or so) across the bottom to add rigidity.
--Madison--
...down at the Ozdust!
Unread 02-01-2007, 23:33
FRC #1640
I noticed that the front and rear c channels are notched for the drive rails on top and bottom. This could be a weak point. Shouldn't the drive rails fit inside the c channel leaving the channel uncut ?
Unread 03-01-2007, 00:00
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
M -
Looks quite nice, and you have obviously put a lot of work and thought into the design. The efforts to minimize the total weight are obvious. The biggest concern you may have is strength in the event of an impact or collision. You might consider making the frame members out of rectangular tube instead of channel. Given the amount of material you are removing, the additional weight from the fourth side of the tube will be minimal, but there will a considerable increase in stiffness of the frame assembly.
Just out of curiosity, what is the spacing between the wheel sets? Is it sufficient to cross a 20-inch wide, 16-inch deep, water-filled moat, should that capability ever be necessary?
-dave
Unread 03-01-2007, 00:02
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Oh goodness.
Unread 03-01-2007, 00:15
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Here we go again...
Unread 03-01-2007, 00:17
Madison's Avatar
FRC #0488 (Xbot)
-dave
--Madison--
Unread 03-01-2007, 00:22
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
-dave
Any crocs?
CRIKEY!
pic: 4 Wheel Strafing Chassis Holtzman Extra Discussion 9 08-07-2009 19:28
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
