Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
View Poll Results: How interested are you?
I'll probably help develop it 13 25.49%
I'll probably beta test 11 21.57%
I'll probably use it 16 31.37%
No interest at all 11 21.57%
Voters: 51. You may not vote on this poll
Unread 03-01-2007, 01:53
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Eclipse Development
I got a basic distro of Eclipse, CDT, and the toolchain up.
Win32 - Eclipse 3.2.1, CDT 3.1.1, MCC18 toolchain (com.astro73.fdt version) (130.6 MB)
This package is for Windows. This should allow teams to get started using Eclipse quickly. All settings are at defaults.
NOTE: This package does not include Cygwin Make. You must have either Cygwin make or a native Win32 Make. MinGW Make will not work. If you get errors about being unable to find "W:\" or similar, you are using MinGW Make.
To make your own version:
  1. Download the eclipse archive, extract
  2. Download the CDT archive file, extract to the same location
  3. Grab the com.astro73.fdt.mcc18.toolchain JAR file from the above file and put it in your plugins dir
  4. Compress the entire directory.
[edit]This project got approved on sourceforge: https://sourceforge.net/projects/firstclipse/. No code up yet, but the project's there. I'll save the joining process for another post.[/edit]
Last edited by Astronouth7303 : 03-01-2007 at 01:57. Reason: Adding bit on SourceForge
Eclipse Plugin Maintaineer? duane Programming 21 31-10-2006 22:34
Eclipse Visual Editor Mike Programming 9 27-09-2006 14:05
using eclipse dasRatsel Programming 82 02-01-2006 13:20
Eclipse code formatter Astronouth7303 Programming 0 24-12-2005 17:39
Eclipse with CDT Nis Programming 2 15-06-2005 09:31
