Go to Post We honor those who are unsung - those without a trophy or a plaque to show their efforts. Those who may or may not get those things... but will still be on the sidelines, helping to guide FIRST in all the right directions. - Amanda Morrison [more]
Unread 01-12-2006, 15:30
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
File System for the RC
It's a little early to mention this, since the code isn't finished, but I can't wait.
Take a look at this cool product that will make it very easy to let the robot control code talk to an SD memory module:
http://www.chipdos.com/
I have always been annoyed that you have to recompile the control program to implement changes to an autonomous program or script. Using this device, you can use short text strings to specify the steps of an autonomous script, and simply edit the file on the SD module connected to your PC, plug the SD back into the RC, and off you go.
I am going to use the SPI interface to talk to this thing, since in the RC environment a synchronous protocol is easier to deal with than async. In this case it can be done with bit-banging on 5 digital I/O pins.
Another thing, it runs on 3.3 VDC, so make sure and have a regulator on hand. Even though the power supply is 3.3 volts, it can interface with 5 volt control signals.
I will post more as I figure it out.
Jim
Unread 01-12-2006, 15:41
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: File System for the RC
I just bought this module from spark fun. I havn't had a chance to test it yet, but it looks good.
Eric Haskins KC9JVH
Unread 01-12-2006, 16:08
AKA: Jim
I first found this device on www.sparkfun.com, but ended up buying a slightly different one from ChipDos...
I like the connector on the Spark Fun version better...
Jim
Unread 01-12-2006, 17:23
AKA: Eric Haskins
So after I saw you r post I decided to try to make my module work, and I found some info you might find useful.
http://www.sparkfun.com/cgi-bin/phpb...ight=dosonchip
Eric Haskins KC9JVH
Unread 01-12-2006, 17:48
AKA: Eric Haskins
Have you been able to make a DOSonCHIP module to work at all?
Eric Haskins KC9JVH
Unread 01-12-2006, 18:02
AKA: Jim
BTW, thanks for the very informative links...
I haven't even powered mine up yet, as I am waiting for the 3.3 volt regulator I ordered...
Originally, I tried to order the development board from ChipDos, but they quoted January delivery, so I changed the order to the plain module. That is why I bought from them instead of Spark Fun.
I would like to get it running from a terminal first because it should be easier to deal with, then I will move on to SPI.
Jim
Unread 01-12-2006, 19:07
AKA: Jim
I found information on another similar product from one of the links you sent:
http://www.saelig.com/miva/merchant....go ry_Code=FF
I will continue with the ChipDos one, since I already have it, and it looks simpler to use. There are many complaints about it, but some people have been able to make it work. I think this will be a handy device to have on the robot...
Jim
Unread 02-01-2007, 01:48
AKA: Jim
Sorry for the delays, I finally got around to making this module work. It has some annoying qualities, but I think we will be able to use it for the upcoming 2007 season.
I will be posting about this project on a blog that I finally set up here: http://www.techranch.com/blog/
Thanks,
Jim
Unread 02-01-2007, 11:42
Bharat Nain's Avatar
Thanks,
Jim
If you don't mind, what are it's annoying qualities and good ones?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 02-01-2007, 13:57
AKA: Eric Haskins
Did you get the SPI working or are you just using an rs232-TTL converter?
Eric Haskins KC9JVH
Unread 02-01-2007, 15:56
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
To talk to CF cards with FAT filesystems, you might be able to use code and designs from Minty MP3 (http://www.ladyada.net/make/minty/). There is code for a PIC18 under the firmware section (fat16.c and cf.c).
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 02-01-2007, 16:15
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Interestingly enough, CF is pin-compatible with ATA, so you might also be able to use conventional ATA hard drives with that code and hardware. (Not that you'd ever need several gigabytes of code space....)
Unread 03-01-2007, 01:54
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
So I see that you get by with 640K of RAM.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 03-01-2007, 03:58
The page isn't loading correctly for me.
I will assume it works on the same protocol as SD, which is SPI. The SPI portions of the IFI controller's PICs are being used for internal function. If so, that software wont be a direct fit for what you want it to do.
Unread 03-01-2007, 08:12
FRC #0030
If the page isn't loading correctly, another copy of the same info is here: http://web.media.mit.edu/~ladyada/make/minty/index.html
Team 30, 2002-2005
PHP file system stuff Ryan M. Website Design/Showcase 3 06-12-2004 07:36
Standardized Scouting System/File Format phrontist General Forum 15 18-04-2004 17:05
Dxf File for the First logo God? Inventor 3 23-01-2003 11:08
Need Dxf file for the first logo Kautz Inventor 3 05-12-2002 16:17
