| For Valentine's Day, I will spoiler with a spring bouquet. |
#16
Re: what usb -> serial adapter should i get?
We have had no problems with the IOGear GUC232A.
#17
If you want a real test of an adaptor, just hook it up to the dashboard, switch it to RC mode, and start reading data. Because the dashboard is set to the highest baud normally supported (115200), any USB adapter not able to handle it will bork.
Any adapter that handles this amount of data will be able to download code as rapidly as a native serially port. I'm not saying others won't, they'll just go slower. |
#18
You know, a little voice inside said I should do my homework before posting...
As an addendum, my post was partly based on my own experience with a USB adapter. Downloading worked, but dashboard didn't. Don't remember what adapter or from whom. It was purple and had a USB B port (the square one). |
#21
I have an interesting situation.
I bought a belkin usb to serial port cable and it could work for the dashboard but using the ifi loader would not detect the controller nor download data. I returned that and bought the radio shack version someone mentioned and its hooked up right this minute. Again the dashboard works fine but downloading and initializing /reading the controller doesn't work. I tried changing the buffer tried changing the speeds up and down to no effect. Can someone please help me. I bought a new laptop and it doesn't have aserial port, which I knew when I bought it but I didn't think the usb to serial port converter would be this hard to get working. I would buy a pcmcia card to serial (which I did) but something I didn't realize the laptop doesn't have the slot, instead its an express card slot, which I can order a serial port for but they're $50+. I would use my old laptop but the screen, harddrive and cd-rom are dying. -Mike |
#22
We are using a VEX USB-Serial cable on my MacBook Pro running Windows XP SP2 with no problems.
The VEX driver is even included in the easyC install (I think... If not, you can always use the CD it came with or download the driver.) This is really convenient. Jacob |
#23
Also, don't even bother with the SIIG expresscard serial adapter. Its just a express card to usb adapter and usb to serial adapter in one card. |
#24
Would you be willing to post the driver? The stores in my area only sell the version which is just the cable which comes with a basic driver. Did you buy the RS # 276-2152 ? I am begining to think its no longer available? -Mike |
#25
2 days ago I returned all the cables and adapters I bought and went to another computer store which had the IOGEAR. I bought the cable, brought it home and connected the cable to my computer and installed per instructions. With all the other cables I could get the dashboard to work but it wouldnt recognise the controller. So today I took my computer and the iogear cable and brought them to our 06 controller. Powered up the other robot hooked my cables together and to the controller. Started IFI loader, clicked on "Controller Verification" and voila the controller is recognised. I an 99% sure I got a bad controller.
![]() So now I will go call IFI and see what I need to do to send in the bad controller and get a new one before we NEED it, I guess I'll use an old controller for programming... -Mike |
| USB-Serial Adapter and IFILoader under Linux | Venkatesh | Programming | 3 | 03-12-2006 22:52 |
| intelitek loader/vex USB-serial adapter driver | MrForbes | Programming | 2 | 07-04-2006 13:37 |
| USB serial adapter for OSX? | Validius | Programming | 1 | 05-01-2006 01:43 |
| USB-Serial adapter | Bill_Hancoc | Chit-Chat | 4 | 03-01-2006 07:18 |
| USB to Serial adapter | John Gutmann | Programming | 7 | 09-05-2005 01:34 |
