Go to Post As a team leader if I do not INSPIRE I have failed, and I do not like to fail. - Mike Martus [more]
Unread 26-12-2006, 12:03
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: what usb -> serial adapter should i get?
We have had no problems with the IOGear GUC232A.
Unread 28-12-2006, 16:54
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If you want a real test of an adaptor, just hook it up to the dashboard, switch it to RC mode, and start reading data. Because the dashboard is set to the highest baud normally supported (115200), any USB adapter not able to handle it will bork.
Any adapter that handles this amount of data will be able to download code as rapidly as a native serially port. I'm not saying others won't, they'll just go slower.
Unread 28-12-2006, 17:21
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
The dashboard runs at 19200.
No, for a few reasons. First, like I mentioned above the dashboard does not run at 115200 so this test won't work. Second, and much more importantly, is that these USB->Serial adapters are fully capable of 115200 speeds - that's not the problem. The problem has to do with buffering built into the USB->Serial adapter and the nature of the USB protocol. These adapters buffer up data coming from the serial port and only transmit it to the PC at certain intervals, either when the buffer fills or when some sort of timeout expires. This adds lots of latency since the way the IFI downloader works is to send commands to the RC and then wait for a response. So, each response takes a while longer than it should, which slows down the overall transfer. This is probably also why some just plain don't work at all.
Unread 03-01-2007, 03:08
AKA: Jamie Bliss
You know, a little voice inside said I should do my homework before posting...
As an addendum, my post was partly based on my own experience with a USB adapter. Downloading worked, but dashboard didn't. Don't remember what adapter or from whom. It was purple and had a USB B port (the square one).
Unread 03-01-2007, 06:53
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Originally Posted by RebAl View Post
Parallax is based on the FT232RL
This is an incredible little chip by FTDI. We use them at work at their highest baud rate. We also run them for days at a time. They work great.
Unread 15-01-2007, 23:32
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I have an interesting situation.
I bought a belkin usb to serial port cable and it could work for the dashboard but using the ifi loader would not detect the controller nor download data. I returned that and bought the radio shack version someone mentioned and its hooked up right this minute. Again the dashboard works fine but downloading and initializing /reading the controller doesn't work. I tried changing the buffer tried changing the speeds up and down to no effect.
Can someone please help me. I bought a new laptop and it doesn't have aserial port, which I knew when I bought it but I didn't think the usb to serial port converter would be this hard to get working. I would buy a pcmcia card to serial (which I did) but something I didn't realize the laptop doesn't have the slot, instead its an express card slot, which I can order a serial port for but they're $50+.
I would use my old laptop but the screen, harddrive and cd-rom are dying.
-Mike
Unread 16-01-2007, 09:46
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
We are using a VEX USB-Serial cable on my MacBook Pro running Windows XP SP2 with no problems.
The VEX driver is even included in the easyC install (I think... If not, you can always use the CD it came with or download the driver.) This is really convenient.
Jacob
Unread 16-01-2007, 10:11
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
I know some people who think the vex adapters work pretty well.
Also, don't even bother with the SIIG expresscard serial adapter. Its just a express card to usb adapter and usb to serial adapter in one card.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 16-01-2007, 15:43
Mike AA's Avatar
AKA: Mike Aalderink
Jacob
Would you be willing to post the driver? The stores in my area only sell the version which is just the cable which comes with a basic driver. Did you buy the RS # 276-2152 ? I am begining to think its no longer available?
-Mike
Unread 16-01-2007, 17:01
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
We've had good luck with this one as well
Unread 18-01-2007, 15:04
Mike AA's Avatar
AKA: Mike Aalderink
2 days ago I returned all the cables and adapters I bought and went to another computer store which had the IOGEAR. I bought the cable, brought it home and connected the cable to my computer and installed per instructions. With all the other cables I could get the dashboard to work but it wouldnt recognise the controller. So today I took my computer and the iogear cable and brought them to our 06 controller. Powered up the other robot hooked my cables together and to the controller. Started IFI loader, clicked on "Controller Verification" and voila the controller is recognised. I an 99% sure I got a bad controller.
So now I will go call IFI and see what I need to do to send in the bad controller and get a new one before we NEED it, I guess I'll use an old controller for programming...
-Mike
USB-Serial Adapter and IFILoader under Linux Venkatesh Programming 3 03-12-2006 22:52
intelitek loader/vex USB-serial adapter driver MrForbes Programming 2 07-04-2006 13:37
USB serial adapter for OSX? Validius Programming 1 05-01-2006 01:43
USB-Serial adapter Bill_Hancoc Chit-Chat 4 03-01-2006 07:18
USB to Serial adapter John Gutmann Programming 7 09-05-2005 01:34
