Go to Post Including the Kinect in the kit a parts is actually an evil plan. The programers are going to spend all their time playing with the Kinect. In competition the robot is just to sit there because it will not have a program. :ahh: - FrankJ [more]
Unread 03-01-2007, 01:35
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Question About Robot Controller
I have been seeing many posts throughout the year about USB on the robot controller and many people are hoping that IFI does it 'right' this year but my question is, whose responsible. FIRST or IFI?
I thought it was FIRST for a long time seeing as they want us to design our own USB adapter but a few posts have made me question IFI.
What do you guys think?
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 03-01-2007, 07:44
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Question About Robot Controller
IFI designs the controller so they would be responsible for the update to USB.
I believe if F.I.R.S.T. asked IFI to change the controller, within reason, it would happen like any other specified component. However I wouldn't assume you'll see USB this year. There are a lot of cost of production, ease of programming, and power management issues involved in this type of change.
I would be pleasantly surprised if we did see the change though.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 03-01-2007, 07:59
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Don't think you will see the serial port replaced any time soon. IFI would just be dropping on the board a USB-to-serial chip if they add USB. Then we would loose a serial port. Which means no co-processors, no LCD's, or anything for that matter that would normally talk via serial. All we would have is the single TTL serial port and if we keep using the camera we would be stuck. They could always replace the PIC with a USB integrated but then you would need a drivers disk for the RC. Which of coarse people could loose see (2006 CBOT Disk). Not to mention the R&D of totally redesigning the RC and writing new master code and user code.
Serial is not the enemy is very good standard that works well with everything. People need to buy better serial ports. Go look for PCMCIA Serial Ports not USB your downloads will scream.
Unread 03-01-2007, 08:02
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
As Peter said, FIRST is ultimately a customer of IFI's at this point. However, they share a wonderful symbiotic relationship.
I forgot exactly when the change occurred, prior to about 2000 FIRST provided a control system in the kit that was designed and perhaps manufactured by themselves. This was done primarily by Eric Rasmussen of DEKA Research. After each robotics season you had to send the controller and radios back to FIRST to be reused the next year.
IFI grew out of a need for a company to design, manufacture and support a FIRST control system. As you can tell from the quality of their products that FIRST has benefited greatly from their involvement.
Unread 03-01-2007, 11:14
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
As a lucky member of the "I've voided my RC warranty" club, I can say with relative certainty that there is enough room on the RC circuit for a USB interface. (If they do add one, I would bet it is just an FTDI USB-to-TTL chip.) I agree with Kingofl337, though, that having the serial port provides a little bit more functionality.
I would like to see a USB interface for joysticks on the OI. That is a different story, though. The OI must be a USB host, not an end-device, I think.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Robot Controller NotaNerd Control System 6 04-11-2004 16:53
A question about taking the robot.... Natsume General Forum 3 26-02-2003 19:31
Robot Controller Josh Hambright Electrical 2 23-01-2003 13:36
Robot Controller srjjs Rules/Strategy 4 08-01-2003 19:08
Robot Controller archiver 2000 3 23-06-2002 22:54
