| Love is in the air compressor. |
Competition Radio Interference Solution?
I was thinking about the IFI lib file. I know how at competitions there can be issues with robots in the pit using their radios interfering with robots on the field.
I was wondering why IFI doesn't add to it's .lib a check for a packet, that the field would transmit, indicating what teams are "in the round". If no packet is received don't do anything but if a packet is received than check the team numbers to the RC's team number and if the team isn't "in the round" than disable the radio. Just an idea... What do you think? |
Re: Competition Radio Interference Solution?
That might make it hard to use the radio, say, at your school.
And, if it can be disabled, it will be. I think the issue is less being one of interference, and more one of safety. Pits are crowded, and the LAST thing anyone needs is one inadvertent motion by the robot, causing an injury. Don |
the problem isnt on a logical layer but on a physical layer. while Im not sure how many channels are used for the first RC I am sure that it is less than 384(thats close to the number at nats). and youll just have teams transmitters stepping on the toes of the field transmitters.
in short that special packet you want to send would just be drowned out. now what they could do is make the recievers dual band(75mhz and 900mhz) and have the field transmitters be one and the teams be another, but thats just over complicating things. |
If you just want to sit in you pit and test your robot, use a tether cable. If you're on a practice field and want to drive around a far easier solution than making switching to dual band radios would be to buy a long tether cable from sandrag (http://www.chiefdelphi.com/forums/member.php?u=2022). |
From the 2007 Manual.
just an idea.....separate and set aside channels for the pit would be my fix. |
#7
Does anyone know what the frequency range of the radio's is? I am assuming it carries a VHF range similar to that used on wireless microphones at the events...another problem which may or may not become more of an issue. I just remember last year at Championships having to switch mics and change frequencies often as my microphone kept taking frequency hits and cutting out. I wonder if this problem is cause for some of the unexplained robot issues we see at offseasons and beyond.
#8
Re: Competition Radio Interference?
when you say "hits", unless I can hear it, it is hard to say if perhaps you're mic was just going a touch out of range or perhaps the signal was multipathing which at such low power than these units run it actually happens. if a robot or other radio keyed up on you're mic freq you should have been knocked off the air good! not just hits here and there ![]() another wireless mic can also knock you off the air. I use this site in canada to look up frequencies http://sd.ic.gc.ca/pls/eng_alpha/web...see_name_input you might have a similar site in the states with the FCC, Industry Canada is our version of the FCC. |
#9
The radio modems provided to us have 40 channels. They are apparently not quite selective enough to be able to use adjacent channels at close range without risking interference; I think I remember someone saying that only 14 of the channels are really usable at the same time in the same area. The user-selectable channels are 04, 13, 22, 31, and 40 (a spacing of 9), with 01 added a couple of years ago. Each field requires six channels, one for each robot. Some regionals have two fields. Championship has four fields running simultaneously, but the opposite corners are probably far enough away that interference isn't a real problem between them. However, there are dozens to hundreds of robots in the pits. You do not want radios interfering with each other when teams are trying to work on their robots. The "no radios in the pits" prohibition is a good safety rule even if you can keep field interference from being an issue. |
#10
Also keep in mind that power of a signal can make a big difference in how a piece of audio or radio equipment squelches. Often if you have two frequencies sitting on top of each other (and they have to be directly on top to really cut something out alot) there will be massive amounts of intermodulation. Instead of the absolute cutoff like you are suggesting would happen with a robot frequency sharing a mic frequency, what you would get would be the higher power frequency winning over, with alot of interuptions, though not quite a complete cutoff. This is an effect we often run into with pager frequencys intermodding over our company radio frequencies. I find that it is very rare for two frequencies to be quite that dead on to be that destructive to a signal. I am still curious however to find what frequency the radios run at. There are tons of radio signals that run rampid in a city...any one of them could cause an issue. Not to mention noise problems from exsisting robot radios that may have damaged parts from all the collisions robots take. Essentially...radio control is a plecomplicated thing! |
#11
Again, folks: It's not logistics - interference can be addressed. It is a safety issue, plain & simple. Don |
#12
While it would seem to be good that neither robot moved on the same channel (given that the field channels are inaccessible by teams), I fear for the time when someone pegs the joystick and the other team using that channel powers down the robot. |
#14
Based on the trend we are seeing with most devices. They will probably be around 2.4GHz range.
#15
Think of what would happen if someone forgot to turn the OI and RC off when it was radio. At least when there is a tether it is a bit safer and helps prevent some of the stuff that happened. Pavan. |
| Interference | Jeremiah Johnson | VEX | 8 | 30-08-2006 07:32 |
| Large CIM Creating Radio interference | Alex Burman | Motors | 1 | 13-02-2006 14:21 |
| Computer Monitor Interference | sanddrag | IT / Communications | 2 | 03-06-2005 22:21 |
| need 2003 radio/help with old radio | MaxM | Technical Discussion | 2 | 04-01-2004 15:31 |
| Robot Controller Interference? | Mr. Van | Technical Discussion | 20 | 22-11-2002 17:18 |
