Go to Post I for one think this kind of robot "love" is absolutely inappropriate for children and both teams should have been condemned for such graphic displays. - Chris is me [more]
Unread 03-01-2007, 12:32
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
SPI Port
Posted in an earlier thread......
On the 2006 controller, the PIC micro had the SPI port #2 connected to the Relay outs 5, 6 and 7. With this upcoming season almost upon us, I have thinking about ways to use an SPI port to talk to custom electronics. Not being a programmer, I wonder if any one has written code for such a purpose, ie using the SPI port with the relay outputs of the RC.
Does anyone have a definitive answer about this? Do we have access to the SPI ports? Can we use them to communicate with external electronics?
Thanks for any help.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 03-01-2007, 13:04
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: SPI Port
In the past, teams have communicated to electronics using one of the two serial ports on the RC (the TTL one the camera normally uses, or the programming port), or by communicating through the digital in/out pins. Depending on what functionality you need, you can use either the serial ports or the digital in/out pins to talk to custom electronics.
Unread 03-01-2007, 13:33
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: SPI Port
The master code does not give you access to those SPI ports. Some SPI devices allow alternative form of signaling like PWM or analog.
Unread 03-01-2007, 14:00
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: SPI Port
I beiliev yongkimleng answered your question in that thread you are refering to. However you can use the program port and ttl port for serial access.
Unread 03-01-2007, 14:41
Re: SPI Port
Also, if I remember correctly, these outputs are pulled up to prevent them being hijacked by another SPI compatible device. I may be wrong though, in which case I will wear a coconut bra at kickoff.
SPI Port on Robot Controller taflick Programming 14 11-01-2007 21:54
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Software SPI Interface Greg Programming 11 08-02-2004 21:38
MSC and SPI Parts Usage sanddrag Kit & Additional Hardware 1 05-01-2003 03:23
SPI Requirement To Purchase archiver 2001 3 24-06-2002 00:33
