Go to Post This is one case where I really wish Andymark didn't listen to their customers so well. - ASD20 [more]
Unread 03-01-2007, 09:14
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Re: Encoder Problem
My mistake. Thanks for pointing that out but would that make a difference for the encoders.
Unread 03-01-2007, 09:41
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Encoder Problem
If you don't recall changing that, then maybe there's others. Obviously, something's different = one works, one dosen't.
How about the fact that you're getting the encoder count for #s 1..4 in one chunk of code, and for #s 1..6 in the other. Is encoder.h set up to use six(6) encoders?
PS: The call to Default_Routine() is commented out in both sets of code, so don't expect any changes there to show up once you get encoders working.
Unread 03-01-2007, 10:17
Re: Encoder Problem
I have tried it both ways. I have tried it with all six encoders enabled and I have tried it with 4 enabled. Other than that there are no changes between the encoder.h files. About the default routine I have tried commented and uncommented but it still will only read one encoder.
Unread 03-01-2007, 13:45
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Re: Encoder Problem
It could be that your interrupt handlers are set up wrong in user_routines_fast.c. Have you checked those?
You should be able to drop the user_routines_fast.c from Kevin's code into your project, unless you are using custom timers, or have already written up some autonomous routine.
At the very least, check to see if InterruptHandlerLow is set up the same in both sets of code.
Hope this helps.
Unread 03-01-2007, 14:04
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Encoder Problem
Grab a copy of WinMerge and check out your 2 files.
http://winmerge.org/
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Re: Encoder Problem
Originally Posted by DustinB_3 View Post
Where would I get a diff tool. I've never even heard of such a thing.
I've had good luck with winmerge, which is an open source tool for comparing folders and files. I think that such a tool would help with your current problem.
Unread 03-01-2007, 14:36
Re: Encoder Problem
I am using the exact user routines fast from kevin watsons frc_encoder code.
Unread 03-01-2007, 20:42
Re: Encoder Problem
Thanks for all of your help. I have finally fixed the problem. I swear that I did not edit the encoder.h file but when I overwrote the old one with one that I got directly from kevin watsons website it fixed the problem.
Encoder Pinout bear24rw Electrical 4 04-12-2006 21:43
Encoder help Windward Programming 21 14-01-2006 15:10
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
