Go to Post This just goes to prove there was life before FIRST (but it wasn't as much fun!) - Ken Loyd [more]
Unread 03-01-2007, 16:46
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: How do you do it?
So are you saying that it is bad to have the infamous
pwm01 = p1_y;
pwn02 = p2_y;
lines that have been used in my code in the past? I'm thinking the velocity control stuff is really cool, but overkill for anything but auton.
If I did use the velocity control (which I now fully intend to implement this year) I would use a lookup table for joystick values matching to velocity settings. But like I said, that seems a bit overkill.
A little off-topic, but I have to teach a newbie this year, and I want to do some really advanced stuff. Should I walk him through it at the expense of getting it done, or do I go as fast as I can like I would if I was doing it by myself, and explain later? I just see advanced programs hard to do when I am programming to teach.
JBot
Aren't signatures a bit outdated?
Unread 03-01-2007, 17:03
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
pwm01 = p1_y;
pwn02 = p2_y;
If that was what was the interface, then it's perfectly ok. It's just sorta limiting. Something like
#define SetVelocity(left,right) pwm01 = left, pwm02 = right
is preferred for this change factor. (EDIT: Typos fixed)
It might be overkill, but why spend 20hrs writing it for only 10s of the match?
This is especially helpful the drive motors are not symetric--they're biased.
Just one word of advice. If you get into fancy motor control loops, I recommend calibrating the victors to absolute. Subtle bugs appear when 127 - 7 drives but 127 + 7 doesn't. You can use my small program to do this.
Unread 03-01-2007, 17:26
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
#define SetVelocity(left,right) pwm01 = p1_y, pwn02 = p2_y
Warning to those who copy and paste, there's a typo, it's pwm, not pwn
Anyhow, if I'm going to be calling a SetVelocity function at all, I'm going to write a feedback loop, or at least a PWM output-to-velocity lookup table because it's fun to be exact (whoo, I guess my obsessive-compulsive is taking over ).
Ahh, good point. Note to self: separate lookup tables between left and right drive.
Will do. I just pulled down the file, the description for it, and IFI's manual for the Victors (which I'm sure I have somewhere already, I just am not sure where. I need to get my obsessive-compulsive focused on that *mess* of a downloads folder...it clocks in at 14.7GB with 2995 files in it... )
Thanks,
JBot
Scary Awesome Autonomous Modes Dan Richardson Championship Event 18 26-06-2006 09:34
EasyC autonomous modes TubaMorg Programming 25 12-04-2006 22:53
Rookie autonomous modes StephLee General Forum 6 30-04-2005 13:16
Autonomous modes? Buster Robotics Education and Curriculum 4 17-03-2004 15:56
Alternative autonomous modes Jon Reese Programming 1 14-01-2004 13:17
