Go to Post Please teams I implore you obey the no saving seats rule. Or at least be very friendly in inviting people to sit with you. - IndySam [more]
Unread 03-01-2007, 17:03
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: How do you do it?
Originally Posted by JBotAlan View Post
So are you saying that it is bad to have the infamous
pwm01 = p1_y;
pwn02 = p2_y;
lines that have been used in my code in the past? I'm thinking the velocity control stuff is really cool, but overkill for anything but auton.
If that was what was the interface, then it's perfectly ok. It's just sorta limiting. Something like
#define SetVelocity(left,right) pwm01 = left, pwm02 = right
is preferred for this change factor. (EDIT: Typos fixed)
If I did use the velocity control (which I now fully intend to implement this year) I would use a lookup table for joystick values matching to velocity settings. But like I said, that seems a bit overkill.
It might be overkill, but why spend 20hrs writing it for only 10s of the match?
This is especially helpful the drive motors are not symetric--they're biased.
Just one word of advice. If you get into fancy motor control loops, I recommend calibrating the victors to absolute. Subtle bugs appear when 127 - 7 drives but 127 + 7 doesn't. You can use my small program to do this.
Unread 03-01-2007, 17:26
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
#define SetVelocity(left,right) pwm01 = p1_y, pwn02 = p2_y
Warning to those who copy and paste, there's a typo, it's pwm, not pwn
Anyhow, if I'm going to be calling a SetVelocity function at all, I'm going to write a feedback loop, or at least a PWM output-to-velocity lookup table because it's fun to be exact (whoo, I guess my obsessive-compulsive is taking over ).
Ahh, good point. Note to self: separate lookup tables between left and right drive.
Will do. I just pulled down the file, the description for it, and IFI's manual for the Victors (which I'm sure I have somewhere already, I just am not sure where. I need to get my obsessive-compulsive focused on that *mess* of a downloads folder...it clocks in at 14.7GB with 2995 files in it... )
Thanks,
JBot
Aren't signatures a bit outdated?
Scary Awesome Autonomous Modes Dan Richardson Championship Event 18 26-06-2006 09:34
EasyC autonomous modes TubaMorg Programming 25 12-04-2006 22:53
Rookie autonomous modes StephLee General Forum 6 30-04-2005 13:16
Autonomous modes? Buster Robotics Education and Curriculum 4 17-03-2004 15:56
Alternative autonomous modes Jon Reese Programming 1 14-01-2004 13:17
