Go to Post heh...do the math! - MrForbes [more]
Unread 01-12-2006, 13:55
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
Re: DeWalt Transmission questions
Originally Posted by StevenB
The chuck/gearbox shaft isn't threaded, correct? I attempted the long lever trick this morning, and broke a Craftsman ratchet. I'll have to try again with a regular wrench or a stronger ratchet.
What size wheels are you using? Do you have any other gearing? What speed does this make the robot go?
We have thought about this, as it would elimate a lot of weight, as well as some of the problems with chain and sprockets.
While your at Sears exchanging that busted ratchet for a free new one (<3 craftsman) pick up a breaker bar. When your putting a huge lever arm on a ratchet, you're really concentrating all that force on the little pin or ball inside that makes the **click-click-click** when you rotate the tool. To a point this is okay, but if you over do it you kill the ratchet. Breaker bars have no such parts and will not break quite so easily.
I have a 36" Craftsman 1/2" BB, and a can of PB Blaster that *always* works
Good luck
stephenyanczura
team 0195 | 2010-Pres. | cyberknights | Conn. | mentor
team 0195 | 2006-2007 | cyberknights | Conn. | mentor
team 1660 | 2005-2006 | harlemknights | NYC | mentor
team 0195 | 2001-2005 | cyberknights | Conn. | student
s.j.yanczura@gmail.com
Unread 09-12-2006, 21:22
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
I searched through the threads a bit and couldn't find anything on this, so I decided to post it here. Our team is also working on using the 3 speed dewalts for our robot next season. The only thing we are concerned about is if the transmissions are shift on the fly or not. Some of the mentors are really questioning this because of noises we hear between 2nd and 3rd gear. How often can these be shifted while in while in motion? If any, what problems have occurered and what should we do to prevent the problems?
Unread 09-12-2006, 22:32
woody's Avatar
woody woody is offline
Too much metal for one hand! \m/
FRC #0033 (Killer Bees)
woody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to behold
We used the DeWalt trannies with CIM motors last year and had no major problems. They will shift on the fly as many times as you want them to. Those noises you hear are normal and shouldnt cause you any problems. The only mistake we made was that, initially, we didn't replace the case, which allowed the plastic ring that actually does the shifting to expand and warp. So just make sure that you replace the front section of the drill case to avoid this. Good luck!
"The greatest of all mistakes is to do nothing because you can only do a little; do what you can." - Sir Sidney Smith
Unread 12-12-2006, 08:19
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Getting the chuck off was easy, once I had the right tools, and was turning the right way! Attached is a pic of the tool I used.
Another question: For those of you who didn't use the third stage, what wheel size and sprocket ratio did you use? We're planning on using an 8 inch wheel, which I think will require approximately a 60 tooth sprocket. Is this correct?
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 12-12-2006, 13:57
opportunist
Breaker Bar FTW
stephenyanczura
Unread 03-01-2007, 18:21
AKA: Steven Bell
We've now made the sun gear adapters and built a test drivetrain with 2 DeWalt/CIMs. The adapter works great, except that I didn't account for the small indent in the center of the back of the sun gear. This allowed the gear and adapter to slide up the shaft ~1/8, to the point where it would shift all the way into 3rd gear reliably. A couple of small washers to fill in the indent solved the problem.
I'm now working on shifting software. Are there tricks to making it work optimally? Joe P. mentions the neutral zone and "Software syncronization" - how does this work?
Thanks!
Unread 20-01-2007, 09:37
MikeZ MikeZ is offline
FRC #0624 (CRyptonite)
MikeZ has a spectacular aura aboutMikeZ has a spectacular aura about
Thanks!
I am curious on how the teams that are not boring out the sun gear but rather using adapters to fit to the sun gear are dealing with the additonal distance (hieght of sun gear) that the transmisison is from the CIM. Do you build a custom case that fits over the transmission and connects to the CIM? Do you build a wider CIM plate and still use the yellow clamshell? Do you cut down the CIM shaft? Thanks
Unread 14-02-2007, 16:02
AKA: Steven Bell
We just cut the clamshell ~3/4 of an inch farther back. The same adapter plate worked, after we cut some small grooves into the side of the clamshell for the screws.
Drawings/Model of DeWalt Transmission sanddrag Inventor 30 23-12-2008 19:01
Dewalt transmission problems? roach1051 Technical Discussion 10 11-04-2006 00:33
Dewalt Shifting Questions Ben Piecuch Technical Discussion 3 20-02-2006 13:40
DeWALT Transmission After Action Report CyberWolf_22 Technical Discussion 7 17-04-2005 00:28
Motor Specs & Transmission Questions Xufer Motors 10 09-01-2005 14:11
