Go to Post I never said there was anything wrong with the kit frame, simply that it was weak. - Viper37 [more]
Unread 03-01-2007, 21:04
CraigHickman
Posts: n/a
pic: 114 Tank module design
Unread 03-01-2007, 21:05
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: 114 Tank module design
6.7 fps is a little slow isn't it? Also, why so much of the output shaft overhanging the side of the frame?
Unread 03-01-2007, 21:08
CraigHickman
Posts: n/a
It's a bit slow for racing, but the tourque allows good pushing power in exchange. The shaft is a previous iteration, and hasn't been cut down to size in the model yet.
Unread 03-01-2007, 21:14
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Wow... That looks so sturdy it isn't even funny. And Very aesthetically pleasing as well. How much does it weigh?
Unread 03-01-2007, 21:58
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
MAKE SURE YOU USE TIMING BELTS!!!
we made that mistake this past year, im advising everybody... NEVER RELY ON FRICTION BELTS!!!....
We shouldve known better....
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 03-01-2007, 22:02
CraigHickman
Posts: n/a
The weight, minus the motors, should come out to be 10-12 pounds. And yes, I did design it to be very strong. I want our drive to be unafraid when he rams away.
The belts we are planning on using are from brecoflex, with the ridge in the middle to keep the belt centered. The backing, or the part that will contact the ground, is red linatex, which has been rated on FIRST carpet to have a 1.6 coefficient of friction.
Unread 03-01-2007, 22:17
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
A++++
However, if I may, I'd like to offer some constructive criticism (really doesn't matter for functionality) but why not turn your transmissions upside to maximize space about the tracks for your superstructure? In doing so it would put your COG closer to the ground helping your system stay upright. If there's a constraint issue, by all means I applogize, i can't tell from this angle.
Looks impressive, Kudos.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 03-01-2007, 22:21
CraigHickman
Posts: n/a
Turn the transmission upside down... I hadn't thought of that. That would actually make things nice and compact, I think I'll give it a try. All I'd have to do it switch one dimension, and flip the thing over. Thanks for the ideas!
[Edit] I flipped it, and it turns out the gearbox is too tall, and stick below the treads. ah well. [/edit]
Unread 03-01-2007, 22:34
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Pretty cool you guys...
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 03-01-2007, 22:45
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I think Andy's speaking more about how the belt is driven -- suggesting toothed timing belt over flat belt. Timing belt is what most teams use, though it's possible to use flat belt if the drive is well designed. For the 2002 season, I helped design a very high traction tank drive system that used flat belts, for example.
My concern is that there's no apparent mechanism to tension the belt. My understanding is that belts need to be ordered with the expectation that they'll be stretched into or onto the drive. A robust tensioning device will allow you to more easily add or change belting and adjust the tension to prevent breaking the belts.
How far does it extend beyond the plane of the floor? It looks like you ought to be able to invert the gearbox and raise the height of the drive pulley from the floor to accomodate the new position of the gearbox.
--Madison--
...down at the Ozdust!
Unread 04-01-2007, 01:20
run the trap!!!
Team Role: Human Player
why build a gear box at all?
Use the side-plates of the treads as the side-plates of the transmissions. Then you would have everything in a nice compact package.
Tensioners aren't really necessary if you use the correct spacing and steel reinforced belts. The other track-drive system currently posted on CD media, is a tried-and-true drivetrain that uses no tensioners.
By the way, those look like some pretty tight turns. We have a spare piece of berco-flex belting, and just from twisting it I doubt it will be able to bend that much.
-Philip J. Fry
Unread 04-01-2007, 08:38
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
1) Why is the wheelbase so narrow? Even without any weight on the top, I can see this drivetrain constantly rocking back and forth onto the steep incline/decline sections.
2) Do the two, lower idler pulleys extend beyond the lower edge of the bottom, flat plate? If not, you'll have some excess friction on that plate, which will kill any efficiency you have. You'll need to lower the idlers, or put more idlers in the center of that plate.
3) Ah, now I see the tight wrap around the driven pulley and it's two idlers. I guess you'll have to read the specs on your specific belt.
4) Using a double motor gearbox, you should be able to gear that a little higher and still have the same pushing force. I would imagine that you'd still slip the belt on the carpet with a bit less torque...
Looks good!
BEN
Unread 04-01-2007, 10:14
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I also am a bit concerned about how small your wheel base is also, on of the greatest advantages of a tank system is having a HUGE wheelbase. I can see that the reason you made it so small is to be able to climb something.. but you wont need that great of an angle to climb anything. Otherwise it is a beautiful system which I would love to see in person if completed, but I also recommend using timing belts... The transfer of power will be much more efficient and you will not have to worry about slipping (thou I doubt that would happen).
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 04-01-2007, 17:48
CraigHickman
Posts: n/a
Thanks for the feedback!
1. The wheelbase was so narrow to allow the bot to drive either direction over an obstacle, and not have to turn around in order to climb steps. This has been fixed.
2. Now they do.
3.This has also been changed to give less tightness to the belt. (my words don't make sense to me today...)
4. We currently like this gearing, as price, size, and machining capabilities allow us to do all the work in house, which saves on time.
For those that care, I added another iteration.
pic: 114 drive module design CraigHickman Extra Discussion 3 06-12-2006 21:59
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
pic: 114 wheels CraigHickman Robot Showcase 12 31-01-2006 15:50
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
