Go to Post I'm always shocked when I see wiring having a bad hair day. - JaneYoung [more]
Unread 04-01-2007, 08:38
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: pic: 114 Tank module design
1) Why is the wheelbase so narrow? Even without any weight on the top, I can see this drivetrain constantly rocking back and forth onto the steep incline/decline sections.
2) Do the two, lower idler pulleys extend beyond the lower edge of the bottom, flat plate? If not, you'll have some excess friction on that plate, which will kill any efficiency you have. You'll need to lower the idlers, or put more idlers in the center of that plate.
3) Ah, now I see the tight wrap around the driven pulley and it's two idlers. I guess you'll have to read the specs on your specific belt.
4) Using a double motor gearbox, you should be able to gear that a little higher and still have the same pushing force. I would imagine that you'd still slip the belt on the carpet with a bit less torque...
Looks good!
BEN
pic: 114 drive module design CraigHickman Extra Discussion 3 06-12-2006 21:59
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
pic: 114 wheels CraigHickman Robot Showcase 12 31-01-2006 15:50
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
