Re: dewalt motor VS. CIM motor
The small CIM (FR801-001) is around 343 W at 12 V. You're thinking of the deprecated Bosch/Scintilla drill motor (2 607 022 078), which is 448 W at 12 V.
Well basically what I am working on is a Robot that basically (for now) just drives around. I finally go my machine shop certifications at Clarkson now so I can make the parts I need. Right now I own a PBASIC control system and some victor 883's but I am also working on the creation of an AVR powered robot controller that can use WIFI for programming and communication. Hopefully it will be able to interface with most USB devices too.
DeWalt motors are used sometimes in battlebots coupled with their transmissions. One source for these motors is the Robot Marketplace, where you can get many different voltages.
http://www.robotcombat.com/marketplace_dewalt.html For more information on DeWalt motors look around for battlebot websites that may have undertaken the research on their own, and compare it to the motor specs provided by IFI. |
well I would not want to use those motors after the advice I just got. Battle bots aren't made to last along time. They are made to get the stuffing beat out of them. They seem like nice motors but i didnt think they would burn out fast
I am just saying that even though they may have a higher nominal power rating than the CIM's, the CIM's may be able to put out higher power in the long run if the motors are allowed to run long enough to get super hot. Joe J. |
but im not downing the CIM, they can easily be modded to way out preform the Dewalts and need to have adiquate cooling. |
#7
I'm curious if the XRP gearbox mentioned in the Nothing But Dewalt (white paper) can be bought off the robot market place website ?
http://www.robotmarketplace.com/stor...gearboxes.html I'm thinking they are the 3-speed gearboxes mentioned , Are there any other places to buy the Dewalt XRP gearboxes without buying the whole drill ? |
#8
Almost all XRP drill models share the same inside parts but the DC930KA works as good as any for our purposes. If one XRP drill model is out of housings, you can use another (just make sure it uses the same gearbox -- that is the heart of the matter). If dewaltservicenet.com is out of the parts, try calling your local Dewalt service center. They have access to a stock of parts that is independent of the parts from dewaltservicenet.com I have had good luck finding parts locally if I was in a jam. Also, know that in my experience, dewaltservicenet.com almost always seems to beat their posted backorder dates so if they are out of parts and claim they will not be in for a month, you may find that they are back in stock in two weeks. Finally with regard to dewaltservicenet.com, you may have to register to get to see the parts lists but it is relatively easy. Good luck. Joe J. |
| CIM Motor Count | Tobaby817 | Motors | 2 | 27-01-2006 11:58 |
| [OCCRA]: Dewalt Motor Specs | troy_573 | OCCRA | 5 | 26-09-2005 00:16 |
| CIM motor issue | dmellich | Motors | 4 | 11-02-2005 11:10 |
| pic: Dewalt Dual Motor | CD47-Bot | Extra Discussion | 8 | 10-12-2004 20:31 |
| dewalt motor stats | greencactus3 | OCCRA Q&A | 1 | 11-09-2004 09:40 |
