Go to Post So, apparently I have my own division in nationals going by the search, "elgin clock division". Why was I not told about this? jeesh... - Elgin Clock [more]
Unread 04-01-2007, 16:01
Re: Set Default Digital inputs to Low? How? bad Analog value?
Originally Posted by Generalx5 View Post
The sensor belongs to OPTEK technologies, OPB742D and OPB606A are the two sensors Im using.
Those devices are exactly suited to being connected directly to the RC's digital inputs. They don't produce voltage; their output is the equivalent of a contact closure. Tie the "E (2)" pin to ground, and the "C (1)" pin to the digital input.
(And don't mess with the IO direction settings. What they do is determine whether a given pin is an input or an output. There is always a pullup resistor on the pin.)
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
OI and analog: Zero value Astronouth7303 Programming 1 02-02-2004 16:00
Resistance to Analog Input Value. Josh Hambright Electrical 12 15-04-2003 16:12
How to access other Digital inputs on OI? DougHogg Electrical 2 12-03-2003 13:57
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
