Go to Post "As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything." — Barack Obama - Ted Weisse [more]
Unread 05-01-2007, 04:24
RonStoppable102 RonStoppable102 is offline
AKA: Ron
None #1098 (GI's)
RonStoppable102 is an unknown quantity at this point
Send a message via AIM to RonStoppable102
Single button function execution
Hey all. Let me first clairify, I've searched for this to the best of my knowledge...
I have a VEX flamethrower robot, currently I have channel 5 set to light my butane pilot light, and channel 6 to spray ether into the flame. I would like to be able to use only one channel to do this (i.e. channel 6 down would light the flame, up would spray), but naturally I can't hold both buttons at once with the code I have, since it just negates everything.
Make sense?
My question: Can I just make the four buttons on the back of the controller act totally independent of each other, so they can run different functions (simultaneously)?
Oh, by the way, Video of the "HOTBot" and Pictures
As always, help is appreciated, I realize with the kickoff looming, everyone is going nuts (as am I!)
Thanks!
Unread 05-01-2007, 09:30
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Single button function execution
Why don't you use a delay?
Have it light the lighter then wait 500ms and then start spraying.
When you release you can have them shut everything down together.
Cool Robot.
Unread 05-01-2007, 09:45
AKA: Ron
None #1098 (GI's)
Younno, not a bad idea. I need to get a light sensor (or thermocouple) in place to check and make sure that the lighter is on before fuel gets sprayed.
Thanks for the idea.
Edit: Thanks, Glad you like it!
University of Missouri - Rolla
Computer Engineering
Mechanical Engineering
User Processor Execution Time Andrew Blair Programming 1 12-02-2006 21:52
Loop execution time for Autonomous code Transporter08 Programming 2 13-02-2005 16:17
Remote Program Execution in Visual Basic Jeff Waegelin Programming 6 14-06-2004 21:15
How to measure execution time? And code size? gnormhurst Programming 17 17-02-2004 08:06
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
