Go to Post No matter what the weight limit is, a large number of teams will *ALWAYS* have trouble making it. - Cory [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 05-01-2007, 08:48
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
New Battery
I see on the shipping and drayage for UTC that MKBattery is the new supplier of batteries. They have their own brand.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 05-01-2007, 09:21
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: New Battery
Andy, I saw the same change. I quickly looked up the batteries for this new supplier, and came up with a spec sheet for a bunch of batteries.
http://www.mkbattery.com/images/ss.pdf
I'm assuming that we'll be receiving the ES17-12, which looks to be the equivalent to the exide ES18-12. The battery size is the same, as is the nominal capacity. However, I noticed one key difference, being that the new MK battery has a max discharge current of 90 amps, as compared to the exide, which can discharge at (a rated) 230 amps. Is this just a case where MK is adding their own safety factor to the battery, or is it really limited in how much it can discharge?
Well, we have one day until we find out, good luck!
BEN
Unread 05-01-2007, 09:24
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: New Battery
Wow!! I hope it's the SVR batteries, because our sponsor NPC-Robotics carries them.
Guess we'll find out tomorrow.
JJ
Unread 05-01-2007, 10:04
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: New Battery
There was some mention of a new battery before on the Forums here looks like the rumors are true
Unread 06-01-2007, 19:44
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: New Battery
Attached MK ES17-12 battery spec. Previous battery had max discharge of 230A for 5 seconds -- new battery is listed as 720A for 5 seconds! Zonks! That's really dumping power quickly! Same 18Ah rating as previous battery.
I haven't compared the derating associated with various levels of discharge curves yet, but anything at or over 20A will drop the available power to only 8Ah or less but it doesn't fall off much more from there up to a 50A draw down rate. It appears that anything close to 50A steady state will last one or maybe two matches. But I also note that if we discharge this battery to 100% of depth then we're only looking at some 100 cycles before the battery won't retain full capacity at charge.
Of maybe interesting note, I quickly threw the battery back on the new charger which is same model as previous years. After even 5 minutes you could easily measure the effect of surface charge. It measured 13.8v off the charger. We pushed the battery through a 50A load for 15-20s and the voltage dropped back into the "nominal" range of 12.7-12.8v which is what a fully changed AGM battery should read w/o surface charge. A suggested method of removing surface charge is 3CA (3*18=54 in this case... 50A was close enough) for 15-30 seconds depending on which document you read followed by a 10 minute rest period.
Bud
Unread 14-01-2007, 16:33
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Re: New Battery
Does anyone know if you can order extra batteries?
Technically by <R46> extra batteries seem to be prohibited...
Items specifically PROHIBITED from use include:
  • Batteries different from, or in addition to, those provided in the kit
I have to be reading this wrong... but in addition to would seem to mean that we cannot buy anymore.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 14-01-2007, 16:51
AKA: Dr. Brooks
no team (WRRF)
Re: New Battery
You can order extra batteries. Just make sure that the manufacurer
is MK and the model number is ES17-12.
Eugene
Unread 14-01-2007, 17:14
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: New Battery
I think by "in addition to" they mean you can't throw a battery pack with 4 Energizer Cs on your robot, for whatever reason. The wording of this was the same last year, and last year you could use additional batteries of the same make/model.
Buying additional MK ES17-12s to use (one at a time) during matches? Good.
Using another type of battery in addition to the MK ES17-12 during matches? Bad.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 31-01-2007, 17:05
Arille's Avatar
Arille Arille is offline
FRC #2135
Arille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to behold
Send a message via AIM to Arille
Re: New Battery
I was wondering where we can buy chargers for the 12V ES17-12 battery.
As a rookie team, we only have 1 charger from the kit, and we dont have any spare chargers lying around from previous years to use.
I've tried contacting MK/Batteries Plus.com, but they only sell the batteries, no chargers. IFI Robotics only has the 7.2V chargers, but not the 12V.
But then again, I could be wrong.
Anyone have any resources??
Unread 31-01-2007, 17:42
Electrical Engineer
Rookie Year: 1995
Re: New Battery
The charger is a Midtronics CXC-2005. A Google search will yield many people willing to take your money. Examples: Here and here.
Mike Betts
As easy as 355/113...
Unread 31-01-2007, 17:51
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: New Battery
And even if you don't need a battery charger, that first link will treat you to some wonderful classical background music. I'm not sure if that helps them sell more batteries or not, but it is amusing.
pic: New year, new hair, new title vic burg Extra Discussion 1 07-10-2006 23:43
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
battery archiver 2000 1 24-06-2002 00:26
battery archiver 2001 0 23-06-2002 22:51
Battery M.I. Technical Discussion 1 04-02-2002 17:13
