Go to Post you don't need a fancy workshop to build a good robot, just determined people. - pacoliketaco [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 13 votes, 4.85 average. Display Modes
  #751   Spotlight this post!
Unread 05-01-2007, 02:07
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Cole's Prediction
The follow long explanation was created entirely by me at 2 AM tonight. Therefore, it might not all be in the regular english and grammar (or spelling) that you're used to. I have attached a zip file containing edited versions of the clue. I have way too much free time when I'm not at VT.
The image is a render from the (future) 2007 kickoff animation video.
The 5 is painted or overlayed onto the diamond plate. The overlay could be from the 5 on something clear infront of the diamond plate. The latter explanation is supported by the fact that the 5 is not perfectly centered on the plate. This is further supported by the higher vertice count of the outer edge of the diamond plate.
The plate could be mounted to a field element at the top or bottom of the picture.
On the right side and the top left corner, you can find faces of the crowd. Adjusting the image shows more faces in the top left corner as well. These faces are comparatively larger than the other features in the picture. I think the faces are behind the camera and are reflections on a curved surface. I can't decide what shape the curve is. The distortion of the camera also affects the faces.
The lighter region in the top right corner seems to block the faces on the right side. This may clue to the shape of the curve.
In the top left corner, the people are being block by what looks like a smooth but steep hill. I think this may indicate a hill on the field. If those are lines painted on the hill, then scaling it in autonomous may be beneficial.
Reflections of red and blue lights can be seen in the diamond plate in the lower left. The blue and red appear to be seperate (i.e. not from a white light source). In the lower right, a red light seems to be on an edge of the field. I think a light (that turns red) is mounted above the drivers' area. The lower portion of the diamond plate is also illuminated by a green light source.
The shape on the right side edge may be one of the example-bots that populate the animations. It looks too delicate to be a field element, but it could also be a game piece.
The only mystery I can't even guess at is the wavey shape on the right below the audience. My only thought is some oddly painted platform or another bot.
I won't lie. The shape in the bottom right looks suspiciously like a fish. I hope is a bot, but it looks like it has eyes, fins, gills, and a tail.
Goodnight and goodluck
-Cole Hasson
-chillaxn@vt.edu
  #752   Spotlight this post!
Unread 05-01-2007, 07:39
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: 2007 Official FRC Game Hint / Email Blast
Originally Posted by fimmel View Post
look in the bottom right, i circled what looks to be a butterfly or something.....i have no idea what the gome is but i found this cool
/forest
In the unmodified hi-res image I thought that looked like a hand.
Thank-you 294 & 67
www.bobcatrobotics.org
  #753   Spotlight this post!
Unread 05-01-2007, 07:47
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
/forest
Is anyone else seeing a fish instead of butterfly? It looks like Dory to me...
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
  #754   Spotlight this post!
Unread 05-01-2007, 08:01
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
I don't see a butterfly, I do see a fish, I don't know what/who Dory is...
  #755   Spotlight this post!
Unread 05-01-2007, 08:12
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
i see a fish as well
dory is a characther in Finding Nemo
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
  #756   Spotlight this post!
Unread 05-01-2007, 09:55
Nagini Nagini is offline
AKA: Vice President
FRC #1212 (The Warriors)
Nagini is an unknown quantity at this point
the number 5 represents the third baseman's position in baseball. The 3rd baseman is 90-120 feet from home. The 3rd base is known as the "Hot Corner" as it is where most balls are hit to.
"We've done the impossible and that makes us mighty." -Mal, Firefly
  #757   Spotlight this post!
Unread 05-01-2007, 09:58
dtape's Avatar
dtape dtape is offline
AKA: Jeff
FRC #0467 (The Duct Tape Bandits)
dtape will become famous soon enoughdtape will become famous soon enough
i see a hnad, not a fish. It could be one of the kickoff animation bots since at least one of the blue ones always has a hand/arm.
  #758   Spotlight this post!
Unread 05-01-2007, 10:27
DUCKIE's Avatar
DUCKIE DUCKIE is offline
Duckie THE Duct Tape Enthusiast
AKA: Andrea Tribo
FRC #0365 (Miracle Workerz)
DUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant future
Send a message via AIM to DUCKIE
I think it is a covered and distorted field shot. You can even see the crowd of smiling faces!
We can lick gravity, but sometimes the paperwork is overwhelming. - Werner von Braun
  #759   Spotlight this post!
Unread 05-01-2007, 11:31
O-H
FRC #0048 (Delphi E.L.I.T.E.)
MUAHAHAHAHAAAA!!!!
I'VE FIGURED IT OUT!!! NOT REALLY!!!!!!! I'M LYING!!!! SERIOUSLY, DON'T TRY THIS!!!!!!
"5" is the password for the encrypted Game Manual files!!!!!!!
You all thought the GDC gave out a wussy game hint, when in fact, they divulged the whole enchilada a few days ahead of schedule!!!!!!!
Those sly dogs.....Plastic fish as game pieces....Cooked ramen noodles for a playing field surface?? Trained chimpanzees to replace the human players......what will they ever think of next?
  #760   Spotlight this post!
Unread 05-01-2007, 12:30
DanTod97 DanTod97 is offline
FRC #0097 (The Cow)
Team Role: Driver
DanTod97 can only hope to improve
it didnt work, was that a joke?
  #761   Spotlight this post!
Unread 05-01-2007, 12:36
Onward through the fog.
short answer, yes, that is a joke.
I'll come back with an edited longer answer in a minute.
Jane
Edit: This is a long thread now and not everyone is reading the thread in its entirety or, I suspect, any of it - perhaps the posts on the last page. If posters have not read the thread, it might be helpful to read the first few pages to get a sense of what it is and also to see that a lot of the suggestions already made are continuing to be thought about. This thread will probably grow a lot longer before tomorrow and within it, the humor and silliness of the members of our community will be evident.
It is a thread of guessing, anticipation, and excitement.
~ Helen Keller
(1880-1968)
  #762   Spotlight this post!
Unread 05-01-2007, 12:37
O-H
Yes.
Trained chimpanzees???? I'd hope it's a joke (although with all the talk of bananas, who knows). And the robots sloshing around through cooked Ramen noodles would make me hungry all day, so I hope that's not true, either.....
  #763   Spotlight this post!
Unread 05-01-2007, 13:13
FRC #0097 (The Cow)
Team Role: Driver
oh wow, haha i didnt realy understand it when i read it all i realy got was that the password was that, but i shoudl have figured they wouldnt do that, well i feel pretty stupid
  #764   Spotlight this post!
Unread 05-01-2007, 13:25
Trust me on this, when Travis starts with the MUAHAHAHAHAAAA!!!!
- don't believe a word he says. You're not stupid, he is just silly.
~ Helen Keller
(1880-1968)
  #765   Spotlight this post!
Unread 05-01-2007, 13:29
FRC #0097 (The Cow)
Team Role: Driver
i just noticed the background could be clear reflective balls, there is one at the bottom that is easy to see and if you look closely you can see its possible the rest of the backgorund is more of them.
pic: 2007 Game Hint? dlavery FRC Game Design 161 07-01-2007 13:42
pic: 2007 Game Piece Hint Wetzel Extra Discussion 39 07-01-2007 00:24
2006 Official Game Hint Discussion Ian Curtis Rumor Mill 753 08-03-2006 20:26
No official FIRST game hint yet?? Elgin Clock Rumor Mill 129 21-12-2004 17:08
