Go to Post Stratagy drives design, not features. - Wetzel [more]
Unread 05-01-2007, 09:21
JohnMorenski's Avatar
JohnMorenski JohnMorenski is offline
AKA: Rusty
FRC #1647 (Iron Devils)
Team Role: Driver
JohnMorenski is an unknown quantity at this point
#25 & #35 chains
ive seen posts on #25 and #35 chains before but i never saw any clear conclusion from people on what they actually preferred for drivetrains it was more just general information
and for the teams that used #25 chain did you ever have problems with it slipping under pressure? or possibly even breaking?
Unread 05-01-2007, 09:44
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: #25 & #35 chains
The clear conclusion we always push is to properly analyze the application and for the loading requirements on the chain. After looking at the stress that will be applied look at the manufacturer's maximum recommended load for the chain you want to use then using sound engineering judgement determine if the chain will be acceptable with apropriate factors of safety.
Don't try to shortcut this and just use something because some one on CD told you it was good. Every application should be looked at seperatly because what may work for me on the 177 drive train may not work for Robin at 173 (we rarely use the same chain size) or Andy on 716, etc.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 05-01-2007, 12:02
B Toth's Avatar
B Toth B Toth is offline
FRC #0075 (Roboraiders)
B Toth is an unknown quantity at this point
We have always used #25 chain on our drive trains. We have never had a problem with it breaking or anything. We even used it with the large CIMs from last year, and they held up through 3 competitions. I have found that #35 is too heavy and is relatively unnecessary for the robot.
Unread 05-01-2007, 12:23
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
This is something my team has been thinking about for a while now. (Team #8) we have always used #35 chain on the drive train in the past, it has been strong and never let us down. But i do think it might be a little overkill. I would like us to use #25 chain because it seems to be more fitting, even though we are not sure if it will stand up.
My suggestion is to try both. I'm not sure how easily you can adapt things to your system, but it you have the opportunity to try both, i would go with that. Put both systems up to some stress tests, you can even do some math to calculate your forces. You never really know how something is going to work until you try it. remember that each application is different, so if 25 works for someone else on their drive train, it doesn't mean it will work for you.
--Dan
Unread 05-01-2007, 13:08
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
We at team 47 have used both #25 and #35 chain in various applications on the robots. Each has its own set of advantages and disadvantages. Yes, 35 is heavier, but easy access to a very wide variety of sprocket sizes is a plus.
#35 is also very forgiving as far as needing exact chain length and how to deal with chain slack, or to eliminate skipping teeth or rolling the chain off.
#25 is better when considering position sensing, it should give you a more precise method if encoders are driven by the drive system chain.
So, there are a couple more things to consider when choosing.
Both will work, just depends on what is important and what you are willing to live with.
Mike
Unread 05-01-2007, 13:11
rockit science rockit science is offline
rockit science is an unknown quantity at this point
We have always used #25 chain for drive systems until last year, when we went with #35. The biggest difference that I can tell is that #35 is much less prone to "jumping off" the sprocket if you get some slack from impact or if it's not optimally aligned. Also, due to the higher stress, #25 tends to stretch more over the life of the robot, requiring more frequent adjustments. A properly designed guide/tension system will negate these issues, but adds complexity to the machine. And just for the record, we've never had a #25 chain break on a drive system. The only drawback that I can see to #35 is the added weight of the chain and sprockets. Since our machines normally come in a good bit underweight (we usually end up adding weight for ballast), this is not a problem for us. Due to the forgiving nature of #35, we plan on using it again this year.
Unread 05-01-2007, 14:07
John Neun John Neun is offline
FRC #0020 (Rocketeers)
John Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond repute
#25 chain is great, but for final drive, we learned the hard way that it is too light. We actually broke links in half at the "neck" in their cross section. B. Toth is of course right when he says to let the stresses be your guide, BUT keep in mind that the drive train sees high shock loading during maneuvering. Stresses can impulsively be very high compared to our usually static analysis. The "slow" end of the drive train is the highest chain load end, so it may pay to lighten the chain toward the motor, but be very careful with #25 on final drive. I'd love to show you the brooken pieces; I would not have believed it if I had not seen it.
Good luck!
Unread 05-01-2007, 14:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by John Neun View Post
#25 chain is great, but for final drive, we learned the hard way that it is too light. We actually broke links in half at the "neck" in their cross section. ... be very careful with #25 on final drive. I'd love to show you the brooken pieces; I would not have believed it if I had not seen it.
I've also seen a few broken #25 chains coming off of hard driven traction systems. Like John, I think the cause was shock loading. A #25 powertrain can be sized appropriately for stall conditions and still fail when shock loaded. Such a failure becomes more likely when load conditions get more aggressive, as usually happens during elimination rounds.
A team might ship its robot thinking that #25 chain is plenty strong enough based on practice driving at home, and continue to believe that through Thursday practice rounds. Most of the broken chains I have seen came from robots that were designed for offense, but switched to being defensive specialists in the eliminations.
Richard Wallace
since 2003
Unread 05-01-2007, 14:22
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
my team came to the exact opposite conclusion. Though it may be heavier it takes stress better. The smaller chain seemed to break more then the larger chain did. If our robot was over weight due to chain weight then we lost the weight other places.
Unread 05-01-2007, 15:09
clean399's Avatar
clean399 clean399 is offline
Mr. Clean
AKA: Nick Hayes
FRC #0399 (Eagle Robotics)
clean399 is a jewel in the roughclean399 is a jewel in the roughclean399 is a jewel in the rough
Send a message via AIM to clean399
Team #399 has been using #25 chain for our drive systems and other mechanisms and we have had no problems that I can remember other than not being able to find a master link in our shop because it is small. We also find that since our robots come to the edge of the weight limit like last year we were exactly 120.0 pounds it saved us that little bit of weight.
Unread 05-01-2007, 15:40
Andrew Blair's Avatar
FRC #0306 (CRT)
Whoa, this seems like about the ninetieth time I've answered this.
In FIRST, more often than not, #25 is quite adequate- almost never breaking or giving problems- if it's tensioned and aligned very well. If not, you're playing roulette, and it will fail, at some point. Maybe sooner, maybe later, maybe seven times at the Pittsburgh regional in 2006.
My suggestion, use #35 from the gearbox to your first wheel, and then you can use #25 after that. If it breaks, you're still moving.
-Sir Francis Bacon
-Albert Einstein
Unread 05-01-2007, 16:12
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
I couldn't agree more with your answer. We have used #35 chain on our drive system mostly because we are a great defensive robot as well as offensive. We dish out as much as we receive and we select our chain by logical reasoning. We analyze the history of playing of teams at regional events we go to as well as our calculated speed and the estimated speed of the opponent. We calculate the forces on the drive system during regular operation and impact operation and then we select our drive chains. As my physics teacher yells when he smacks his ruler on the desk "IT'S PHYSICS!!!!!!!!!!!!!!!!!!!!!!"
Championship - Delphi "Driving Tomorrows Technology"
Unread 05-01-2007, 16:33
b-rant's Avatar
b-rant b-rant is offline
AKA: Brantley Brokaw
FRC #0364 (TEAM FUSION!!)
b-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the rough
Send a message via AIM to b-rant
you should have a poll but #25 I believe is the best solution for FRC if done correctly, if not you may slip.
Unread 11-01-2007, 18:35
Superstitions's Avatar
Superstitions Superstitions is offline
Gadget Wizard
FRC #0039
Superstitions is an unknown quantity at this point
Smile Re: #25 & #35 chains
In comparing the chains for our arm we are trying to find out how much #35 and #25 weighs per foot. Googled it and could not find the specs. Maybe someone who has a scale handy could weigh 10 feet of it.
Thanks, Jeff
Unread 11-01-2007, 18:38
#25 -- 0.09 lb/ft
#35 -- 0.276 lb/ft
Richard Wallace
since 2003
VEX Chains chewy VEX 13 21-11-2006 14:14
chains sburro Technical Discussion 13 07-10-2004 11:37
power transmission NOT using gears/chains? Frank(Aflak) Technical Discussion 37 21-05-2003 12:50
chains in 3ds tinsLee123 3D Animation and Competition 4 17-02-2003 00:14
chains enjoiwheels Inventor 0 08-02-2003 19:33
