pic: 6 Wheel Drive Chasis
Re: pic: 6 Wheel Drive Chasis
1/8inch wall is plenty thick for the upper structure i may even suggest 1/16th wall but only if you plan on bumpers. And as far as the omnis go i'd play with it once its done it'll be easy to switch them out.
Why is the footprint so short? Couldn't you move the front and back wheels out more to keep it from rocking back and forth whenever you drive and stop?
Also, I like how you pre-cheesed the top of the frame. It's nice to start early so you aren't scrambling at the end. |
Quote: Why is the footprint so short? Couldn't you move the front and back wheels out more to keep it from rocking back and forth whenever you drive and stop?
Yes, a longer wheel base would be better, but being a rookie this past year, my inventor skills are not the best and did not know how to change it when it was all done. |
hmmm... 11 hrs. to build and test your prototype. Better hurry
!How are you running the chains? Are all six wheels powered, or are you just powering the center wheels with two CIMs each? I seriously doubt it will weigh 35 lbs; I estimate between 45-50 lbs., which isn't bad. Nice work |
That weighed 35 pounds, but that is without chains, sprockkets, and the iproperties are set to default on the motors. 45 - 50 pounds is proably closer. |
| pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side | Vince | Extra Discussion | 6 | 09-01-2008 19:17 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| pic: Omni Wheel Drive -- Top | Richard Wallace | Extra Discussion | 4 | 05-12-2005 18:55 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| pic: 6 wheel drive train pick | CD47-Bot | Robot Showcase | 3 | 14-04-2004 07:10 |
