Go to Post FIRST doesn't just prepare you for engineering, it prepares you for life - sciguy125 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-01-2007, 17:40
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Stock Chassis Problem!!
We dont seem to have all the required parts for the stock chassis!
We seem to be missing the axels, or some form of axel. These axels are not printed in the kit checklist.
Thanks,
Team 1560
Unread 06-01-2007, 17:49
Billfred's Avatar
Billfred Billfred is online now
Re: Stock Chassis Problem!!
You've got to supply those yourself. Look for 3/8" bolts of sufficient length, 4" if I remember correctly. And make sure they're high-strength (Grade 8 is usually recommended)--these things are what take the hits.
Unread 09-01-2007, 18:59
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
team 2200 came up with a different solution to the problem
Picture is of 1 completed axle (in the wheel)
and 3 axles in various stages of completion.
- Bochek
Unread 09-01-2007, 19:37
Andrew Blair's Avatar
FRC #0306 (CRT)
Yeah, trouble is, as I remember, the KOP checklist stated that the included bearings were to be 3/8" ID, but the actual ones are 1/2" ID. And the Kitframe has 3/8" ID axle holes, so teams will have to be creative, or order some non-standard 3/8" bearings.
-Sir Francis Bacon
-Albert Einstein
Unread 09-01-2007, 22:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Or look at this thread....
http://www.chiefdelphi.com/forums/sh...ad.php?t=51207
Unread 11-01-2007, 15:15
pfreivald's Avatar
AKA: Patrick Freivald
Anyone know where to get more of the wheels pictured (as in, the kit wheels from last year or the year before)?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 11-01-2007, 15:17
MrForbes's Avatar
AKA: Jim
they are not the same as last year, and you can get them from Andymark
http://www.andymark.biz/firstwheels.html
Unread 12-01-2007, 07:29
pfreivald's Avatar
Ok, thanks.
Team 1551
I write books, too!
Unread 12-01-2007, 07:38
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
If you are talking about the wheels from the last couple of years supplied in the kit, they came from skywheels. This year seems to be a lot better wheel with a great difference in traction.
Unread 12-01-2007, 08:14
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Skyway actually
http://www.skywaywheels.com/
Stock Frame... Herbie698 Technical Discussion 21 11-03-2005 20:16
Stock transmission sj31419 Technical Discussion 2 17-02-2005 21:51
Stock transmission sj31419 Electrical 2 17-02-2005 21:51
Key Stock? dddriveman Technical Discussion 6 12-02-2004 23:50
2 mm key stock Andrew Technical Discussion 8 03-02-2003 22:29
