Go to Post Maybe LabView needs to have a watchdog for goofy programmers... - johncap100 [more]
Unread 06-01-2007, 19:23
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
Re: Creative uses for the USB Port
NICE! now i feel boring... i was just imagining joysticks and xbox controllers, i like the suggestion of a laptop. is it allowed?
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
Unread 06-01-2007, 19:30
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally Posted by Rick-906 View Post
is it allowed?
No, since the laptop is battery powered.
Besides, the Chicklet is a USB host. Laptops are also hosts. Two hosts cannot simply talk to each other (without special hardware and software in between).
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
is it allowed?
Per <R83>, no.
<R83> All equipment connected to the joystick ports of the Operator Interface must be powered
solely through the power available through the port. External power sources of any type are
not permitted on any equipment connected to the joystick ports. Portable computing
devices can not be connected to joystick input ports on the Operator Interface. Power-passive
devices (e.g. joysticks that draw their power solely through the Operator Interface
joystick port) are permitted.
The one exception to this rule is Innovation First Incorporated
USB adapters (IFI Part Number USB-CHICKLET) may be used to connect USB devices to
the joystick ports of the Operator Interface. If used, this USB adapter must be powered with
a 7.2V battery similar to the back-up battery. Teams can not use power from the
competition port or any other source to power the USB adapter. The USB adapter must be
positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during
inspection and operation in a match.
I'm still not sure what the reasoning is behind this, but there it is. Sorry.
JBot
EDIT: Well, someone beat me to it. Oh well.
Aren't signatures a bit outdated?
Unread 06-01-2007, 19:35
bobotics319 bobotics319 is offline
AKA: Andrew Levasseur
FRC #0319 (Bobotics)
bobotics319 is an unknown quantity at this point
nintendo wii... that would be so much fun!
Unread 07-01-2007, 00:56
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
exactly what i thought. the remote can be used for the arm and the numbchuck for the well... movement of the robot...
any ideas
but how hard would it be to do a ps3 or a wii controler, bc of the motion sencor
hey, what about vibrate when you come n contact with anouther robot.
now that would be fun
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 07-01-2007, 01:22
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
any ideas
The only thing is that the wii controller and probably the ps3 controller also requires batteries, and I think that this is not allowed. Also remember that you still are limited to 3(?) analog inputs per port.
Unread 07-01-2007, 09:21
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
This is not the case. The O/I ports have 4 analog and 4 digital. The analog usage is user selectable. There are 4 modes for all of the gamepads including the x-box/360. Mode 1, for example, uses two analog channels for the y axes on the left and right. The other two analog channels are alllocated for digital use. The Chicklet uses the upper nibble of each analog byte which gives you 4 extra digital per analog channel. So the total available digital slots in mode 1, is 12. I think 12 is enough. If it is not, then give some tasks to the other operator.
Thanks, Mike Copioli
CTRE
Unread 07-01-2007, 13:28
KevinH's Avatar
KevinH KevinH is offline
AKA: Kevin Hamer
#1307 (STAR (Labs))
KevinH will become famous soon enough
Send a message via AIM to KevinH
Using a Guitar Hero controller is key. 7 buttons, 1 two way switch and of course, an analog input whammy bar.
There's also of course midi keyboards, but you could always get something like the DX1 input system and just build your operator controls with that. I'd love to see a laser keyboard too. Maybe a fragpedal... This was a smart move, opens a lot of possibilities to teams that wouldn't have the time or resources to build controllers themselves. I do hope that there's still plenty of custom controllers too though, PS2/PS3/Xbox controllers aren't the end all be all...
Unread 06-01-2007, 23:21
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Originally Posted by JBotAlan View Post
Per <R83>, no.
JBot
I believe the reason is so that one may not offload the RC using, for example, a laptop on the OI side. By receiving sensor info via the dashboard port and sending PWM info and digital output info through the joystick ports, this would be possible.
Unread 06-01-2007, 23:48
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
How about a simplified computer keyboard?
How about a USB computer mouse?
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 06-01-2007, 23:53
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
What about a computer keyboard and a mouse, and you could use drive your omni drive bot FPS style..
Uses for FP Motors? Ryo_Himura Motors 21 13-01-2006 17:24
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
Top 10 Uses for the 10 Point Balls EddieMcD Chit-Chat 10 30-03-2004 18:29
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
Creative uses for servos? dddriveman Motors 34 19-07-2003 00:33
