Go to Post New mentor joins one team and ends up impacting several in the same region. I like that. :) - Travis Hoffman [more]
  #76   Spotlight this post!
Unread 06-01-2007, 19:43
Alex357 Alex357 is offline
Operator
AKA: Alex
FRC #0357 (Royal Assault)
Team Role: Operator
Alex357 is on a distinguished road
Re: Rules Questions
I could not find any mention of a specific starting location for each robot... do they just have to be in the home zone?
2006 Philadelphia Regional - Chairman's Award
2006 Philadelphia Regional - Delphi Driving Tomorrow's Technology Award
2006 Florida Regional - Engineering Inspiration Award
2006 Florida Regional - Finalists
2005 Pittsburgh Regional - Delphi Driving Tomorrow's Technology Award
2005 Pittsburgh Regional - Autodesk Visualization Award
2005 Pittsburgh Regional - Semi-Finalists
2004-05 Philadelphia Regional - Engineering Inspiration Award
2003 Chesapeake Regional - Chairman's Award
  #77   Spotlight this post!
Unread 06-01-2007, 19:45
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Rules Questions
Originally Posted by Dylan Gramlich View Post
FIRST Q&A enough said.
Agreed, Q&A answer needed before we can be sure.
If you look at <G29> of last year's manual, however, it uses the same wording:
Originally Posted by LAST YEAR'S MANUAL!
Detaching Mechanisms - ROBOTs may not intentionally detach parts or leave multiple mechanisms on
the field. Violations will result in a 5-point penalty. If an intentionally detached component or
mechanism impedes access to a ramp or a goal, the offending ROBOT will be disqualified from the
match.
Originally Posted by fireball3004 View Post
I also have a question about deploying such extending items, and if they are included in the Starting Position Maximum height, or if they can remain un deployed until the match is started.
For your starting position, the extending items can be in any position you want, extended or unextended, as long as the starting position of the entire robot fits within the starting size limits.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
  #78   Spotlight this post!
Unread 06-01-2007, 19:57
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Rules Questions
Originally Posted by CBailey View Post
if you may not touch any part of the field then it is practically impossible to get all 3 robots of the ground
Anybody see anything yet about driving on to one of the tubes to get 4" up? Can't intentionally damage the playing piece, but obviously you don't want to damge it because you need it to be functional. Thought in the demo video that in the corner of the screen it had a robot on top of a tube.
  #79   Spotlight this post!
Unread 06-01-2007, 20:09
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Rules Questions
Somehow once you drive on it I don't believe you will be 4" high anymore...
And it actually is addressed somewhat in the manual:
Originally Posted by 2007 Game Manual
<R37>...Bumper height has been specified so that ROBOTS will make contact bumper-to-bumper and so that the GAME PIECES will be pushed rather than pulled under the ROBOTS....
While this isn't really a rule, it suggests that it wouldn't be advised to drive on game pieces, and would be against the spirit of this and other rules (namely no damaging field elements).
  #80   Spotlight this post!
Unread 06-01-2007, 20:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Rules Questions
Originally Posted by dhoizner View Post
If you are carrying an inner tube, let's say using the vacuum pump, and another robot in passing knocked the tube out of your possesion, would that count as removing possesion from a team, will the 10 pt penalty be assesed? <G36>
<G36> Goal defense - ROBOTS may defend SPIDER LEGS by pushing and/or blocking other ROBOTS as they attempt to HANG GAME PIECES. If a ROBOT is holding a GAME PIECE, a ROBOT on the opposing ALLIANCE may not grasp/attach to the GAME PIECE in order to remove it from their POSSESSION or prevent them from HANGING. A violation will result in a 10-point penalty being assessed to the offending ROBOT.
That wording suggests that contact with game object in the possession of other robots is allowed, as long as you are not actively attempting to grasp, pull, or attach to them. So, if a gripper allow for an object to fall off easily, you should be able to bump it off.
  #81   Spotlight this post!
Unread 06-01-2007, 20:16
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Rules Questions
What if another robot pops the game piece in your possesion?
  #82   Spotlight this post!
Unread 06-01-2007, 21:19
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Re: Rules Questions
Originally Posted by <G55>
Deflated GAME PIECES - A GAME PIECE that has been deflated is evaluated the same as one that is inflated when determining the match score. Intentionally deflating a GAME PIECE is considered field damage (see <G34>).
So if it's on purpose, then they might be disabled according to <G34>, or be required to remove whatever piece popped it and then be reinspected. Either way though it still counts as a normal tube.
  #83   Spotlight this post!
Unread 06-01-2007, 21:33
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
Re: Rules Questions
For all the people speculatin on the multiple item on the floor, consider your robot as a seperate part. So having a ramp detached and your robot on the field would count as multiple parts deployed and in violation of that rule.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
  #84   Spotlight this post!
Unread 06-01-2007, 21:50
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Re: Rules Questions
Originally Posted by robind View Post
I'm interested in a clarification of rule <G40>
"<G40> Detaching mechanisms - ROBOTS may not intentionally detach parts or leave multiple mechanisms on the field. Violations will result in a 10-point penalty per incident. If an intentionally detached component or mechanism significantly impedes access to the RACK or an ALLIANCE ROBOT during the END GAME, the offending ROBOT will be disqualified from the match."
Since it says "parts or multiple mechanisms" which would lead me to believe plural, it would seem that a robot would be allowed to simply drop a ramp at the beginning of the match and let other robots climb up on it at the end. As long as it was only one ramp.
Why would it only have to be one ramp?
  #85   Spotlight this post!
Unread 06-01-2007, 22:14
robind robind is offline
FRC #0675
robind is an unknown quantity at this point
Re: Rules Questions
multiple parts. But whatever, I can't really see much of a use for being able to do that anyhow.
  #86   Spotlight this post!
Unread 06-01-2007, 22:22
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Rules Questions
Originally Posted by tb222 View Post
What confuses me is the terms in bold above... First they say you may not leave multiple parts, and then they talk about penalties for single (an intentionally detached component or mechanism) parts...
Regardless, it seems as long as your component does not "impede access to the RACK or an ALLIANCE ROBOT," the 10-point penalty may be worth the risk. Then again, is it truly in the spirit of FIRST to intentionally earn a penalty to win the game
It is NOT in the spirit of FIRST but to some people, even in FIRST, winning is everything and to win is to prove something to others. But this is very true in the world we live in. Numbers speak for themselves, but how you got those numbers does not matter as much.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
  #87   Spotlight this post!
Unread 06-01-2007, 22:24
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Rules Questions
I do agree with many on this, By detaching a ramp from your robot it is considered to be a part of your robot, because if it isn't then it is a violation of the rules, but there are many other ways to get a robot off the ground .
Also, it is impossible for all three robots to be off the field at the end of the game as at least one must lift ( and/or support) the other robots.
I do have a question though. Are we allowed to carry more than one of our own game pieces?? It may of been mentioned in the brodcast, but I was busy writing things down and may of missed it. Someone on my team told me that you couldn't and someone else told me there wasnt anything against it. Just need to clarify.
  #88   Spotlight this post!
Unread 06-01-2007, 22:29
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Re: Rules Questions
You can only be in possession of one game piece at a time. <G09>
  #89   Spotlight this post!
Unread 06-01-2007, 22:31
FRC #1360
Re: Rules Questions
oh, ok thanks! Didn't even notice. I think I skipped the first few words in that rule. lol
  #90   Spotlight this post!
Unread 06-01-2007, 22:44
pbhead pbhead is offline
FTC #1123
pbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nice
Re: Rules Questions
deployed stuffs desigend to lift robots...
I dont know about you all, but depoyed sure sounds like... umm.... let me google it.
de·ploy (dĭ-ploi')
v., -ployed, -ploy·ing, -ploys.
v.tr.
To position (troops) in readiness for combat, as along a front or line.
To bring (forces or material) into action.
To base (a weapons system) in the field.
To distribute (persons or forces) systematically or strategically.
To put into use or action: “Samuel Beckett's friends suspected that he was a genius, yet no one knew . . . how his abilities would be deployed” (Richard Ellmann).
v.intr.
To be or become deployed.
deploy
verb
To put into a deliberate order: arrange, array, dispose, marshal, order, organize, range, sort, systematize. See order/disorder.
deploy
v
Definition: redistribute, station troops or weapons
The verb deploy has 2 meanings:
Meaning #1: place troops or weapons in battle formation
Meaning #2: to distribute systematically or strategically
anyway... deploy sounds like... to put/place. and in most of those examples, what is deployed in not connected to the thing that deployed. I think you should be able to deploy a ramp, or other lifting mechanizim... and as long as they arnt physically attached by anything more than touching... then you should be able to used deployed ramps.
In a certain game i play(not the one in sig), when i die... i get the message: deployed defences shot down pbhead! and the defences are certainly not attached to who ever deployed them...
I dont know... i think a robot should be able to make itself score those points... its kinda odd if it could not.
and that rule about mechanizims.... what i think they mean there, is that you cant have a seprate entity on the field... meaning you cant have a romote contoled crame to lift yourself up... once its disattached... it cant act like a mechanizim... so if you... say blew up a really big ballon under your robot, and then unhooked the air... and then it would elevate you, and would no longer be part of your robot... since its just a bag 0' air...
i dont know... i am stupid.
Persons attempting to find a motive in this narrative will be prosecuted;
persons attempting to find a moral in it will be banished;
persons attempting to find a plot in it will be shot.
By Order of the Author -Mark Twain
Game/Rules questions - PLEASE Search before you post! Stu Bloom General Forum 3 12-01-2006 21:44
rules questions... archiver 2001 5 23-06-2002 22:40
Technical Questions, Rules Brian_Lim Rules/Strategy 6 11-01-2002 14:09
Questions on rules nick reynolds Rules/Strategy 1 08-01-2002 01:02
Questions about rules ahecht Rules/Strategy 9 07-01-2002 22:45
