Go to Post FIRST builds bridges, and absolutely should not build walls. - Jacob Bendicksen [more]
Unread 06-01-2007, 19:29
Teger's Avatar
Teger Teger is offline
Team 100 Animation
FRC #0100
Team Role: Animator
Teger is an unknown quantity at this point
Amount of power drawn by FRC controller?
Its a relatively simple question; How much power does the FRC controller (the one on the robot, I hope I have the right name...) draw from the backup battery?
Also, the FRC board has the ability to output power, and according to the rules of this year, the only legal way to use a backup battey is through the FRC controller...would it also be possible to use this output power to power the fisher-price motors? or, for that matter, any of the motors in the kit?
Unread 06-01-2007, 19:34
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Amount of power drawn by FRC controller?
I am unsure of this. I know that after a few minutes the RC goes dead if running on backup, but I'm not sure if that's because of a timer or the battery going dead.
The backup battery will not power any motors...ever. Your main battery is the only power source for motors, and motors must be powered by Victors or Spikes.
Good luck
JBot
Aren't signatures a bit outdated?
Unread 06-01-2007, 20:29
teh_r4v3 teh_r4v3 is offline
AKA: Rajeev Sharma
FRC #1511 (Rolling Thunder)
Team Role: Student
teh_r4v3 is on a distinguished road
Send a message via AIM to teh_r4v3
From the 2006 controller docs (the 2007 kit still uses the 2006 controller):
The +12V and GND connectors on the Robot Controller are intended to accept power from a +12V
battery. The current draw for the Robot Controller is typically between 0.75A to 1.5A. The maximum
voltage allowable is +15.0V. Exceeding the +15.0V limit may damage internal voltage regulators and
will void the warranty. The minimum required voltage to maintain radio link is +7.0V.
On the controller board website:
The total combined current supplied from all 16 Analog and 18 Digital +5V Power header pins is 1 Amp. The 1 Amp max can come from a single +5V Power pin.
So basically the controller board probably won't be able to power any drive or arm motor without some external power.
The backup battery (or at least last year's, I'm not sure if the new one is different other than being yellow) was 700mAh I believe, which would power the controller anywhere from less than half an hour to less than an hour, assuming "typical" power usage. With such little power, I doubt it would be useful for powering motors even if you were allowed to. (You're only allowed to use it as a backup battery, and as far as I know there's no way to channel off power from it when the main battery is connected and charged.)
Rajeev Sharma
Team 1511 Rolling Thunder
hoojamomma?
Unread 06-01-2007, 20:37
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
JBot
From what i know about the back-up battery is that it is strictly a back up as it name states it to be. The only motors it can power are the servo motors on the camera system. Everything else gets powered form the main battery through victors or spikes.
Championship - Delphi "Driving Tomorrows Technology"
Unread 07-01-2007, 13:23
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
You can only drive motors (other than servos) using Spikes or Victors.
Why not just limit the speed using the Victor?
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 07-01-2007, 23:00
The specification above (0.75 amp to 1.5 amp) is nearly correct. The five volt regulator built in is designed for a max of 1.5 amps but the RC by itself draws up to 0.75 amp. The RC is designed to draw current from the backup battery when the main battery falls below 8 volts for more than a few seconds. During this time, the backup battery supplies current to the RC and radio modem to maintain communications and the backup also supplies current to servos connected to the PWM outputs of the RC. When using the CMUCAM, the backup is supplying current to it as well.
The backup battery cannot be used to power any motors on the robot other than servos when connected the serov is connected to the RC.
As a final note, all motor control is disabled by the event controller and so all motor control must be powered by the main battery through the main circuit breaker and must controlled by either Spikes or Victors connected to the RC per the Robot section of the manual and the electrical drawing.
Unread 08-01-2007, 17:39
Aboynamedkim55's Avatar
Aboynamedkim55 Aboynamedkim55 is offline
AKA: Alex Kimmelman
FRC #0075 (The Roboraiders)
Team Role: Electrical
Aboynamedkim55 is a jewel in the roughAboynamedkim55 is a jewel in the roughAboynamedkim55 is a jewel in the rough
Send a message via AIM to Aboynamedkim55
The backup battery powers the camera, so if you have the camera this year you need a good battery in the robot to have you camera working well
Proud to be a J&J Team
-2007 Chesapeake Winners with 293 & 203
-2007 Chesapeake GM Industrial design
-2007 NJ regional Chairmans award
-2007 NJ regional Autodesk visualization award
-2006 NJ regional engineering inspiration award
-2006 Boston regional Autodesk visualization award
-2006 Boston regional engineering inspiration award
What is the FRC Robot Controller Power Consumption amateurrobotguy Electrical 4 02-03-2006 00:23
wich fuse should i use for the FRC Robot Controller? or yaniv Electrical 3 18-01-2005 14:50
FRC Program State Frozen at Power-up WillyC Control System 4 14-02-2004 18:05
2003's FRC Robot Controller ahmed Programming 7 18-12-2003 22:43
power connector for 2004 EDU controller kc8nod Robotics Education and Curriculum 6 25-11-2003 16:59
