Go to Post I suspect the GDC is enjoying watching teams wrap their heads around this ranking algorithm.... and is probably a bit surprised that it has taken teams so long to clue in to the options this ranking system presents to them. - dtengineering [more]
Unread 06-01-2007, 21:15
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Re: Creative uses for the USB Port
Originally Posted by Dianna Bartone View Post
If that is the case, is there anything helpful we could use the second driver for? It was probably left in the rules in case someone did want to use old system, but maybe there could be a potential advantage to be gained...
The second driver can pass tubes to the human player if you find that that helps. Probably because you can only hold one tube on the robot at once, the human player won't really be rushed. The second driver could also help to coach the main driver, or help communicate from your drive team to the other drive teams on your alliance
Uses for FP Motors? Ryo_Himura Motors 21 13-01-2006 17:24
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
Top 10 Uses for the 10 Point Balls EddieMcD Chit-Chat 10 30-03-2004 18:29
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
Creative uses for servos? dddriveman Motors 34 19-07-2003 00:33
