Go to Post Listen to this FIRST: Thank you - Daniel Brim [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #31   Spotlight this post!
Unread 06-01-2007, 21:08
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: 2007 Kit
Originally Posted by colin340 View Post
no no no not the van door take the mini bike or the window motor but don't take the van door
i think we need to make a memorial
I too shed a tear for the van-door motor. It has been a very good friend over the years.
  #32   Spotlight this post!
Unread 06-01-2007, 22:15
AKA: Dr. Brooks
no team (WRRF)
Re: 2007 Kit
Originally Posted by bhsrobotics1671 View Post
if we didnt use last years transmission are we allowed to use it this year? last year we used a custom and it was horrible getting it to work..so we have last years that was in the kit of parts that we are wanting to use. any one know??
please let us know
3rd year team but you can still consider us rookies
The only way that you could use last years (unmodified) transmission is if it is a COTS mechanism that is currently available for sale to all of the teams. As IFI is no longer selling it, you are likely out of luck.
Eugene
  #33   Spotlight this post!
Unread 06-01-2007, 22:17
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Re: 2007 Kit
I also liked the van door motor and the old batteries. Espically since we just made a really nice charging station last year. I really like the new AndyMark stuff and the new pneumatics.
  #34   Spotlight this post!
Unread 06-01-2007, 22:18
Gdeaver Gdeaver is offline
FRC #1640
Re: 2007 Kit
Comparing last year KOP drive train with this year. 2006 the drive train with the addition of 2 21 tooth sprockets, 2 28 tooth sprockets, a box chain and 4 kludged up wheel adapters gave a team a nice 4 motor 4 wheel drive base. Could be done in one night. With this year's kit we get 2 wheel drive and the opportunity to spend allot more $$$ to get 4 wheel drive out of the kit drive train. What do we do? Buy 2 more 56 MM gear heads and associated sprockets and go with four wheel independent drive or buy the 2 cim gear case add on and use 1 56 mm gear head. I have reservations about putting 2 cims into 1 56mm gear head. Maybe others will have a more analytical comment on the input handling of the banes bot gear heads. Then there is the output shaft loading issue that Banes bots warns about and the additional bearing plate they sell because of it. Then again we could just use the 2005 KOP gear boxes. They're in pristine condition and have proved to be robust.
The Andy Mark KOP wheels have much softer rubber. The Skyway wheels last year wore down allot. I'm afraid the softer compound may be a wear problem. I think we may put disposable rubbers on the wheels. Also I think the Skyway wheel profile was a positive when driving on carpet.
I can see the BB gear heads being a positive for our arm drive.
The encoders available from BB are a definite step forward.
Over all with less then 24 hour I have to say the kit is 2 steps forward and one back. Our team is going to need some additional funds to make this work this year. Last year we got away real cheap.
  #35   Spotlight this post!
Unread 06-01-2007, 22:38
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: 2007 Kit
I like this year's kit box- mainly the new radios and the vacuum engine excite me.
This box also provided me with my third legal license for LabView
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
  #36   Spotlight this post!
Unread 06-01-2007, 22:49
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: 2007 Kit
Eugene
Maybe i'm wrong, but doesn't AndyMark sell some kind of variant that is similar to the KOP Transmissions that we used to receive? As seen here - http://www.andymark.biz/am-0011.html
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
  #37   Spotlight this post!
Unread 07-01-2007, 01:28
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Re: 2007 Kit
Anyone notice the lack of cylinders in the kit? For that matter, <R105> mentions a "Pneumatic Components Order form", but I haven't found that yet either. Anyone know if these are part of the SMC bag or what is supposed to be in that bag? No mention in the KOP Checklist.
  #38   Spotlight this post!
Unread 07-01-2007, 03:36
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: 2007 Kit
Dear Bosch Van Door Motor,
Everyone here at FIRST really misses you. You were the best high torque output that we knew, always there cranking away. I will never forget the day when you helped us win that regional... *sniff* I know we had our differences, like that fact that our machining was in inches and you were all metric, but we never let that get in the way of building the best robots ever. Sorry if I get a little emotional, but I hate saying goodbye to a friends. I will miss you a lot for this year's game!!!
Gabe
P.S. Tell me if you are planning on coming back next year!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
  #39   Spotlight this post!
Unread 07-01-2007, 17:34
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: 2007 Kit
I just want to verify that, as per the KoP checklist on the FIRST site, we're only supposed to have one Fisher Price motor and gearbox. We received two in our kit.
Did anyone else get two?
--Madison--
...down at the Ozdust!
  #40   Spotlight this post!
Unread 07-01-2007, 17:38
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: 2007 Kit
We got two, I was just about to post the same question.
  #41   Spotlight this post!
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: 2007 Kit
We got 2 as well.
Ricky Quinones
Director of Sales - VEX Robotics
  #42   Spotlight this post!
Unread 07-01-2007, 17:39
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: 2007 Kit
We recieved two as well.
  #43   Spotlight this post!
Unread 07-01-2007, 17:44
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: 2007 Kit
We got 2 fischer prices also.
I also really like the AM wheels. Our initial tests show they have a really good coeffcient of friction. They also seem extremely easy to add bearings and a sprocket to.
Anyone have and information about how good the traction is after the treads have been worn in? Is it better, worse, or the same as when they're fresh and new.
Thanks for the great wheels.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
  #44   Spotlight this post!
Unread 07-01-2007, 17:47
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: 2007 Kit
We got two.
I love the new BaneBot stuff.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
  #45   Spotlight this post!
Unread 07-01-2007, 21:41
Re: 2007 Kit
We received two FP as well.
2007 Canadian kick-off Jan-6-2007 media coverage Mark Rozitis FIRST In the News... 3 07-01-2007 18:31
2007 Kit Transmission Brandon Holley Rumor Mill 1 06-01-2007 01:40
***FVC Programming Kit/Bundle Kit Upgrade*** KathieK FIRST Tech Challenge 0 04-12-2006 19:57
**FIRST EMAIL**/2007 Kit of Parts Info Mark McLeod FIRST E-Mail Blast Archive 15 09-11-2006 15:38
pic: Kit Transmission Upgrade kit Andy Baker Extra Discussion 17 29-01-2006 01:27
