Go to Post The rules are the rules, but if the rules get so ridiculous some of us may choose not to play anymore and that is the bigger shame. - Paul Copioli [more]
Unread 07-01-2007, 01:32
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Re: 2007 Default Code?
I believe the 2006 code IS the 2007 code. Seeing as MPLAB compiler version and IDE did not change from last year, I would assume that everything works the same. Check Kevin's site. The files were updated last year, but now say "2007 Default".
That is convenient for us proggers as we don't have to port our already running cam routines Now...to work with 2 lights at the same time *rubs chin*
I quit FRC over 2 years ago (more if you're reading this past 2010).
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
default code archiver 2001 2 23-06-2002 22:53
