Go to Post Everyone knows the best way to lose weight is to turn the robot upside down, shake vigourously, and throw away anything that falls out. - Mark Hamilton [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Unread 06-01-2007, 22:32
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Re: Robot ideas
Originally Posted by Rick TYler View Post
This is going to be so much fun this year! Since I'm not on an FRC team right now, I can speculate wildly without having to worry about giving up any Top Sekrits.
RobotAddict and I were talking about the most radical idea we could think of and came up with the following.
* Ignore the ringers. Let your alliance partners do that.
* Build a 12-inch-tall, maximum-weight bot with multiple-speed transmissions
* During most of the match, play defense
* At the end, deploy pneumatic forklifts off both sides of your bot, and lift BOTH of your alliance partners 12" off the ground
Would you pick an alliance partner that had lifting as its only non-defensive contribution?
We considered this. Every year there are teams that are picked for defensive alone. This idea is kinda nice since you can run defense or could also serve as a ring runner during the match-basically carry and deliver the rings to your alliance partners, this might be useful if you wanted to score on the rack side away from you. The problem with this type of robot is you are kinda screwed if the bots can't get back in enough time, for example they are broken and in pieces.
Unread 06-01-2007, 23:22
Re: Robot ideas
Since my fantasy forklift would use pneumatics, it wouldn't be hard to include a small arm that could place a ringer on the low spider posts. A little offense, a lot of defense, capable of picking up two bots at once. Sweet...
Unread 06-01-2007, 23:26
y2d2 y2d2 is offline
Eat? During build season?
FRC #0670 (Homestead Robotics Team)
y2d2 is an unknown quantity at this point
Re: Robot ideas
Too bad we can't attach to field elements One of our mentors suggested suction cup-ing to the plexiglass at the end of the match to get 1' off the ground
670's thinking about an elevator-type mechanism...
- Silicon Valley Regional
- Davis Sacramento Regional
- Championship
Unread 06-01-2007, 23:43
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Re: Robot ideas
I like your idea with the short and defensive robot but what if you are put onto an alliance in qualifying that has two other teams that barely do anything (i.e. wheels on box bots) then you lose a match because of that. I feel each robot should be self sufficient so that it can score well. They only count points for scoring offensively. Your idea will be a good plan for newer teams to design a simpler robots that might not have the ability to make an arm or program a light sensor. Good post.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 07-01-2007, 00:38
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Robot ideas
Want robot ideas? Look to 2005 and 1997, at least for ring manipulation.
Unread 07-01-2007, 01:17
Coop Coop is offline
None #1717
Coop is on a distinguished road
Re: Robot ideas
our team decided the most awsome(and hardest and least likely lifting mechanism) is akin to a inflatable raft. keep it rolled up till the last 15 seconds or so, or more. drive to home zone, unfurl it(note that it is NOT detachable, it remains attached to ones robot via pnuematics/air cables). alliance robots then drive ontop of the "raft" and it is inflated with much speed. if anyone can accomplish this, i will be impressed. have fun.
btw, first post, gogo penguins!
-coop
Unread 07-01-2007, 01:24
BigRed's Avatar
BigRed BigRed is offline
FRC #2044 (Big Red Robotics)
Team Role: Student
BigRed is an unknown quantity at this point
Re: Robot ideas
I'm from a rookie team and we discussed the idea of focusing on a robot that could lift and play defense, like the one mentioned before.. One post stated that there are a possible 596 possible points an alliance can get, but how many of the possible points is a team truly likely to get, for instance, based off of previous competitions. I mean, If my team can get 60 points by lifting the two alliance partners off the ground would that make us a valuable alliance partner in the finals?
Unread 07-01-2007, 01:46
Re: Robot ideas
I am scared. NOT!! Now I have ideas to use, once we decide strategy and requirements. You guys should slow down. You can't design a robot in 12 hours or so. Well, I suppose you can, but the one that someone takes 3 weeks to design because they were analyzing the game for 1.5 weeks will slaughter it. Take some time to analyse the game first, then design using these ideas. I predict that some of you, with the level of analysis shown here, will be very surprised at a competition.
Unread 07-01-2007, 01:47
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Robot ideas
-coop
Cool idea, but not legal. An inflatable bag is not a pneumatic device you're allowed to use in the Robot Rules.
Unread 07-01-2007, 02:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot ideas
Yes, you would be a valuable alliance partner. But keep in mind that your alliance partners may have problems, if they fall over or have a drive malfunction they won't be able to make it to the end zone and you won't be able to lift them, and won't get your 60 points. If you can score some rings in addition to lifting, you'll be even more valuable.
Unread 07-01-2007, 10:22
The Arizona Mentor
AKA: Andrew
Re: Robot ideas
Building off that, you'd only be a valuable alliance partner for certain robots. If you can only lift robots in the "long" configuration, then you wouldn't be valuable to anyone who builds a "wide" robot.
Lifting mechanisms are going to require some very careful and good thinking if you want to ensure you can lift ANY robot.
Unread 07-01-2007, 10:37
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Robot ideas
Originally Posted by supertroopa86 View Post
Our team had no trouble getting on the ramp when right next to it even with the
transmission supplied in the kit of parts
My team had no issues either, but there were lots of teams that had trouble maneuvering up the very wide ramp at the end of the match. Maneuvering up a robot that is arbitrarily rotated, will probably move slightly as you get on, and is only slightly larger than your own will be very difficuilt.
Edit: Actually, I guess a flower-petal design with some light metal would work decently. If you have a 1ft-tall robot with a 3ft-tall deployable ramp, then the angles required aren't as bad (18 degrees). If you go for a very tall robot when not folded, then you just have a 11 degree ramp for the mounter to traverse, which is definetely doable. It'd still make me very nervous to have another robot on top, but it'd be workable. If the ramp was side-mounted, then it should be wide enough that navigating it wouldn't be impossible, though you'd still have a tipping risk if your alliance partner came on too fast.
Edit2: Like the attached renders I just made. Which I guess is very much like the wildstang shots shown before.
ID:	4826  Click image for larger version
Unread 07-01-2007, 11:54
MrForbes's Avatar
AKA: Jim
Re: Robot ideas
We were tossing around ramp ideas yesterday....the more you think about it, the more solutions there are. Building some of them would be quite challenging, but you really do have a lot of room to work with as far as storing a ramp, if you are careful with the design of both the ramp, and your tube handling arm.
Unread 07-01-2007, 12:11
Bongle's Avatar
Re: Robot ideas
Just thinking more about ramps, you could help with a lot of the tipping and space issues by making a bent ramp so that it greatly increased the amount of flat space to drive onto.
The attached one would have a 2 foot long flat section, then a 3 foot ramp section that climbed at 18-degrees to a height of 12 inches. The total amount of flat space would be 3 feet wide (maximum length of robot) and 4 feet long (2 feet on the ramp + maximum width of robot). Mechanically all you'd need is a tiny latch on your manipulator arm (presumably on the left side of the shown robot) and maybe a tiny pusher to get the ramp to fall down. Problem with this is that you're now limited to a 100lb robot that needs these two huge towers on it, and has to be built to support other 120lb robots. I'm not an mechanical engineer, but it seems that this design of ramp could be built pretty lightly if you were creative with materials.
If you put some vertical posts on the underside of the ramp that had really grippy feet, you might remove the robot-shaking issue when mounting as well.
Unread 07-01-2007, 15:53
Red Mage's Avatar
Red Mage Red Mage is offline
Owner of Holistic Omniscience
FRC #1546 (Chaos Inc)
Red Mage is on a distinguished road
Send a message via AIM to Red Mage
Re: Robot ideas
undoubtedly you would need to be able to score to even be considered for an alliance. But the ability to earn 60 points would be helpful
Don't Blink. Blink and you're dead. Don't turn your back. Don't look away. And don't Blink. Good Luck.
Fundraising Ideas chipvalley59 Fundraising 6 08-09-2005 13:58
Any ideas for an "art robot" ninratmny General Forum 11 11-11-2004 20:25
Any ideas for a robot name? Ryan M. Chit-Chat 20 10-02-2004 23:36
Ideas SH_Animation 3D Animation and Competition 9 26-01-2004 16:53
Robot Types (post your ideas here) Rick Rules/Strategy 30 10-02-2002 12:09
