Go to Post Angry Teams will not get the field going any quicker trust me on that! - mtaman02 [more]
Unread 07-01-2007, 02:19
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: 2007 Default Code?
Originally Posted by amateurrobotguy View Post
That is convenient for us proggers as we don't have to port our already running cam routines
Yes, exactly. Last year Dave dropped the hint that the CUMcam2 would be back, and I'm hoping teams have spent some time in the off-season working with the camera.
Now...to work with 2 lights at the same time *rubs chin*
The best thing to do at this point is to spend some time thinking about what the camera will "see" from the starting area. It's important to know a few things:
1) The camera has a very wide field of view of ~60 degrees.
2) The camera will not always "see" two lights. Recent data taken on a regulation field shows that the camera will only detect a single light if it's within about +/- 25 degrees of rotation relative to the camera.
3) If two lights are detected by the camera, the camera will return a single rectangle around both lights.
4) If only one light is detected by the camera, the number of pixels reported by the camera will be small (~10).
-Kevin
Kevin Watson
http://kevin.org
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
default code archiver 2001 2 23-06-2002 22:53
