Go to Post I'm sure you can come up with something, with a bit of warped thought! ... and if not, warped thinking is what your team's Engineers are for! :) - kmcclary [more]
Unread 07-01-2007, 12:12
notquitehere188 notquitehere188 is offline
FRC #1006
notquitehere188 is an unknown quantity at this point
Sitting on top of tubes
Will sitting on top of tubes at the end of the match be allowed for points if the tube holds you 4 inches off the ground or are the tubes considered part of the field
Unread 07-01-2007, 12:17
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Sitting on top of tubes
I'd check with FIRST on this question.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 07-01-2007, 12:18
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
The rule says you can't be in contact with any part of the field, and last year the balls were considered part of the field, so I would assume the tubes would also be.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 07-01-2007, 12:26
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Well last year if we were partially on the ramp, but held up off the floor by a ball, we were still considered on the ramp and given the points.
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 07-01-2007, 12:29
I laughed out loud. Last night, my son RobotAddict came up with this idea, too. I really enjoy the creativity of the FIRST crowd.
Has anyone else noticed that this might be the Year of the Hovercraft? (In deference to you very serious utes in the audience, this is a joke. Yes, I know that scoring will be done with the power off and that a hovercraft would be touching the arena floor before scoring is complete.)
Unread 07-01-2007, 19:44
We actually tried setting a 120-pound robot on top of a pool ring this afternoon to see how well it worked.
Mostly, it didn't.
The pool ring seemed dangerously close to bursting, so we didn't put the entire weight down. The robot was very unstable, and would likely have fallen over had we let go of it.
This is definitely a question for the Game Design Committe, but even if "field element" doesn't include "game piece", I think it would be extremely hard to make the idea work reliably.
Unread 07-01-2007, 19:58
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
If you could distribute the robot's weight over multiple tubes, i.e. if a light robot were to rest itself on top of multiple tubes using a flat piece of material, they might hold the weight.
Then you'd have to ask whether that's possession of multiple tubes - are you controlling the movement of the tubes, or just using them passively after positioning them one at a time?
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 07-01-2007, 20:00
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I don't think FIRST would be very happy with your team if you are constantly wrecking all of thier tubes. They aren't free.
Unread 07-01-2007, 20:08
Covey41 Covey41 is offline
Covey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of light
At the Kickoff in Manchester someone suggested that it might be easier to deflate a tube before you tried to score it, this statement was overheard by one of the GDC members, they very pointedly made the statement that any intentional deflating of a tube would result in a DQ.
Now I know that this is my opinion, but I would think that putting a 100+ lb robot on top of one these tubes, and having the tube pop, would be considered intentional.
Unread 07-01-2007, 20:15
raymaniac's Avatar
raymaniac raymaniac is offline
meE wEr HeER
FRC #0116 (Epsilon Delta)
Team Role: Animator
raymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to beholdraymaniac is a splendid one to behold
How would the robot get on the tube to begin with?
Yeah I thought of that (and mentioned it in another thread).
However, a hovercraft would probably get knocked around too easily, so it should probably have wheels it uses until the end of the match.
I think it would be awesome to make a hovercraft. I'm sure if you showed it off at an outreach event everyone would be impressed.
I guess that means no spikebot
Everyone have fun at the regionals Atlanta. Or else...
Vote for 116's animation!!!
Unread 07-01-2007, 20:42
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
When we inflated our tube, we wanted to distribute the weight over the tube, so we put a drafting board on top of it. We didn't have a robot on hand, but we stacked the entire KOP on the board, and it sank to about 6.5" , which is interesting. Has anyone else noticed that they are really only about 7.5" high, not 9.5 like the rulebook claims? So it sank about an inch, although I can't give you a number for how much weight we used. Tomorrow when the weightroom is open we're gonna go try it out with exactly 135 lbs (have to add in bumpers).
Unread 07-01-2007, 20:58
DCA Fan's Avatar
DCA Fan DCA Fan is offline
FRC 812/3476 Mentor
AKA: George
FRC #0812 (Midnight Mechanics)
DCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond repute
The rules state that intentional damage to the tubes call for disqualification, as they are field elements. Therefore, sitting on a tube will not give you any bonus. That said, if some team manages to make a robot that can sit on a tube without popping it or permanantly damaging it, I will be very impressed.
2016 FRC Orange County Regional Co-Chair, FRC San Diego Emcee, FRC Ventura Emcee, Vex Worlds Emcee
2015 FRC Emcee: Inland Empire, San Diego, World Championship. VRC Emcee World Championship
2013-2016 FLL Judge Advisor, Southern California/Legoland
2001-2005 FRC294 Beach Cities Robotics
2005-Present FRC812 Midnight Mechanics
2012, 2014 FRC3476 Code Orange
2003-Present Volunteer, FRC/FTC/FLL/VRC
NEMO | San Diego Regional | Orange County Regional | FIRST California
Unread 07-01-2007, 21:01
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
if you notice that in the video you had Dean on a tube and it will hold his weight he is at least 140 lbs. these tubes can hold 120 lb robot without a problem.
The question is, is the tube a element of the field. I do not think so.
If you can do this. it will be easy to sit on two tubes. you hold one and sit on the other at the end of the game
Building FIRST robots since 1995
BVT Robotics
Unread 07-01-2007, 21:33
Yohan's Avatar
Yohan Yohan is offline
AKA: John P
FRC #0368 (TKM.368 (Team Kika Mana))
Yohan is on a distinguished road
Doesn't sitting on two tubes count towards multiple possession of tubes, which is not allowed?
Unread 07-01-2007, 21:35
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I think it would not count because it is laying on a game piece.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
pic: Top Gun Top Wheels Rick TYler Robot Showcase 4 04-02-2006 11:13
Top 10! Andy Grady General Forum 144 02-03-2004 18:49
One Robot Sitting on top of another question rkyro22 Rules/Strategy 14 09-01-2003 03:48
Top 5! Andy Grady General Forum 16 06-01-2003 00:20
Both alliances sitting in endzone with 10 seconds left? Mike Soukup General Forum 7 24-03-2002 18:55
