Go to Post They call us super nerds. I say thank you :D - Gregor [more]
Unread 04-01-2007, 17:32
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Tank tread
Originally Posted by DeepWater View Post
Maybe but I find it hard to believe that the two omni wheels (driven in the same direction) would have enough traction to overcome any "decent" traction wheel. Maybe 2 AndyMark Omnis vs. 2 of the KoP Skyway wheelchair wheels but then wouldn't it just be much more efficient to just use 4 omni wheels?
Omni-wheels (theoretically) have no less traction in their "Y axis" (forward/reverse) than regular wheels do, so they would have the same slippage point as the drive wheels. In practice this is not always true (particularly with traction wheels and omni-wheels with plastic rollers), but with the right wheels it could be. Say they use AM Trick Wheels with the black EDPM rubber rollers and lower traction drive wheels.
Unread 04-01-2007, 18:37
chs1368 chs1368 is offline
FRC #1368
chs1368 will become famous soon enoughchs1368 will become famous soon enough
Re: Tank tread
but if we get hit from the side, if we have 4 omni wheels, we're gonna move in the direction we're hit in
Unread 04-01-2007, 19:58
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
Re: Tank tread
Originally Posted by chs1368 View Post
the reason i put motors on the omni wheels is that if were stationary and turning we could turn a lot faster, also this would allow us to turn while we were in motion (like moving forwards) another is say for last years game if we had a stationary turret to shoot those balls, we could make precise adjustments to where our robot was facing
you said the extra motors (on the omni wheels) were so you could turn faster but a 2 wheel drive setup will turn very quickly whether you have 2 un-powered omni wheels or ball casters and i am not sure you would be able to make more precise turning with them unless they were geared to drive slower
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 04-01-2007, 22:03
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Tank tread
The whole point of an omni-directional drive train is that you can out maneuver a pusher type robot like a tank tread, 4WD, 6WD, 8WD, etc. so you never have to worry about getting pushed around. A non-omni directional robot (typical FIRST type 4WD, 6WD, tank tread, etc.) is designed to push it's way around but will not usually be as maneuverable as an omni robot. I think you are trying to do both but in doing so you may not succeed in doing either very effectively. My suggestion is to think about two separate designs (one made for maneuverability and one for pushing) and then on Saturday decide what your game strategy will be and go with whichever design you feel will best match your game strategy.
Unread 04-01-2007, 22:40
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: Tank tread
one more note on treads : if they are properly tensioned(not overly tight and not loose) they can be very reliable. in 2006 we only broke only one tread, any other replacements were do to wear over the two previous regionals, compare that to 2004 when we snapped 4 over three regionals and nationals on account of losing tension in the middle of a match.
Unread 05-01-2007, 16:25
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Tank tread
Hey guys, ive read all your posts and i have to say alot of you have great arguments for your reasoning, and i agree with most of you. Everythign in the end comes down to the game and the history of design of the teams you will be opposing at regional events. For team 1368 i suggest analyzing the game as well as the opponents then decide what you want to do, also as for belt drives the friction force of the belt on the pulley is less than the force put out by a pushing robot, so if you get hit and pushed, you WILL get pushed and your belt system WILL slip on the pullies. Also i suggest a simple rocker drive system with powered wheels in the center powered by CHAINS with 2 omnies on at the sides of the robot, this configuration works best.
Championship - Delphi "Driving Tomorrows Technology"
Unread 05-01-2007, 16:59
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Re: Tank tread
With Splined(Toothed) pulleys,from brecoflex, you will not get pushed from the front and with the correct belt profile(V shaped profile in the center, TK10-K13) your belts will never slip sideways, this mixed with the long contact patch basically means you won't get pushed sideways either. the only pushing weakness of treads is due to your gearbox, if you don't have enough torque you will get pushed front to back or if the opponent catches a corner of your robot you can be spun.
Unread 06-01-2007, 22:18
eshteyn's Avatar
Re: Tank tread
There seems to be a mix up, i meant that the belts will lose grip on the pullies they are driving and will slip on them, even if the belt is toothed, there will be a point where it is stretched out a little bit from use and will no longer grab on to the pulley like it used to, then it will slip on the pulley.
Unread 06-01-2007, 22:27
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: Tank tread
Track drive / tank treads have there good points and bad.
On a light unit the tracks will tend to come off the idler wheels... and they will be a lot of adjusting to make them work right. They great for climbing ramps and pushing other bots out of your way (if you got the motor and gearing for it) but other than that there just a headache.
I think speed gonna be needed for this game... wheels the answer.
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 07-01-2007, 01:32
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
Re: Tank tread
Hey, just some quick insight if u do decide to use a tred system. I am on team 288 and we have been using treds for the past 7 or 8 years and it takes ton of time to get everything to work properly. If you still decide it will take a long time which will take away from the other problems you'l face like scoring. It took us 3-4 years including the off season to perfect it. If you can get it to work efficeintly in 6 weeks... you eather were lucky or very smart people.
Unread 07-01-2007, 14:11
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: Tank tread
team 61 has been doing tracks for over 10 years and we stop due to Breco flex could not make us a belt that would not rip. the power we where using where ripping the belt. at $340 a belt we went with wheel last year. Had some good results. Track are great and are better than wheels only if you can keep them from breaking. the power that is given to us now is way to much for the Breco flex belts.
we go with 6 wheel system almost the same results as a tank drive system
if you want to see the tracks go to our web site
http://www.valleytech.k12.ma.us/robo...photos2004.htm
Building FIRST robots since 1995
BVT Robotics
Unread 07-01-2007, 14:48
team 1094's Avatar
team 1094 team 1094 is offline
FRC #1094
team 1094 is an unknown quantity at this point
Re: Tank tread
if you are going to use a tank tread desing you mite want to keep in mind that it is very hard to ketp a tank tread on with out giving it tooo much slack. also im couries on how you plan to trun your robot.
kyle from (team 1094)
Unread 07-01-2007, 15:54
Andrewpbhs's Avatar
Andrewpbhs Andrewpbhs is offline
FRC #2023 (PiraTech Engineering)
Andrewpbhs is an unknown quantity at this point
Re: Tank tread
If your Robot is made correctly, and centered in it's weight the robot should have no problem turning around in a 360 degree....
tank tread inventor file SgtMillhouse648 FIRST Tech Challenge 0 14-09-2006 11:12
Tank Tread Wheel Joe_Widen Technical Discussion 8 29-05-2006 23:28
Tank Tread Stair Climber 114gopher Technical Discussion 9 12-12-2005 21:41
Tank Tread suppliers? Rombus Technical Discussion 2 22-02-2005 11:01
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
