Go to Post In fact, our robot YOLOs so hard it does drive-bys on the refs. - TrevorKN [more]
Unread 07-01-2007, 15:31
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Multiple cylinders on a solenoid
This is probably going to sound like a stupid question but I wanted to make sure.
If I wanted to put two or more cylinders (or pistons or whatever you like to call them) onto a single celenoid (via 2 T-quick connect fittings) would it work and/or would the effect be any diffrent than having two celenoids each on one cylinder off of one regulator?
Unread 07-01-2007, 17:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Multiple cylinders on a solenoid
It will work. They will not extend at the same time, most likely. Water, air, and electricity all take the path of least resistance, so the piston with the least load/friction will extend faster and/or before the second piston. This would be a problem even with seperate solenoids, though not quite as big. The only sure fire solution is basically to seperate the two solenoids with check vales and things so they're operating from different pressure sources.
Unread 07-01-2007, 19:57
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
We have run two cylinders off of one solenoid valve many times. It is better if both cylinders are identical, but it is not necessary. The only difference is that the solenoid valve has a maximum flow rate and if you want the cylinders to move fast, two will move slower than one. I would look at the specs of the valve and pick the one with the highest flow rate if the speed is a concern.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 07-01-2007, 22:52
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
it is done regularly - especially with pneumatic shifters to be sure they are firing at the same time.
you will have a hard time noticing any difference in response.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 07-01-2007, 23:31
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
although, at least with the andy mark shifters, you can notice that there is a diffence in the time it takes a gear to engage
if you're not careful you can turn when you shift
Unread 12-01-2007, 00:06
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Actually, you'd STILL get the above problem with that method. Think about it. Nothing has changed WRT the loads themselves.
Off the top of the head, I can only think of two ways to insure they move together perfectly in sync:
A) Mechanically tie the pistons together via some mechanism. (But heck, if you did that, why bother with two cylinders in the first place???)
B) Use closed loop controls, position monitoring, and more complex valves than are supplied, to monitor and "throttle back" the faster cylinder based on its motion. (This is MUCH more complicated, and rarely if ever worth the effort!)
Honestly, if you REALLY need two things to go EXACTLY together, figure out a way to mechanically couple them, and drive them both with one cylinder simultaneously.
One example might be to use a differential bell crank. With servos, you simply use opposing ends of the "X" horn on the top of the servo, and run links out both ways.
With a cylinder, you "float" the "X" - two opposing ends go to your two devices, and a third end runs over to your cylinder. When the cylinder pushes or pulls on the crank, the two devices switch together.
(Warning - With ANY bell crank system, be sure to use a spring loaded "servo saver" ends to prevent over-run freeze-up. Otherwise, the load that switches first and hits ITS stop will freeze the crank. This could prevent the other load from fully switching!)
Does this make sense?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Pneumatic Cylinders MASherry Pneumatics 1 09-01-2005 18:49
Legality of controlling 2 cylinders with 1 solenoid mtangolics Pneumatics 4 19-02-2004 21:29
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Q&A Discuss: Cylinders + Solenoid valves CD47-Bot Extra Discussion 1 05-02-2003 17:21
Cylinders + Solenoid valves Greg General Forum 2 28-01-2003 09:29
