| My crate or yours? |
| View Poll Results: Getting on top vs letting on top vs other. | |||
| We will allow one partner robot to get 4" high on us |
7 | 3.02% |
| We will allow one partner robot to get 12" high on us |
36 | 15.52% |
| We will allow two partner robots to get 4" high on us |
6 | 2.59% |
| We will allow two partner robots to get 12" high on us |
144 | 62.07% |
| We will climb onto other robots at the end. |
25 | 10.78% |
| We will only score ringers until the ending buzzer. |
14 | 6.03% |
| Voters: 232. You may not vote on this poll | |||
#16
Re: Letting robots on top vs getting on top of robots
...all at the same time, so none of them are touching the ground...
I think a lot of teams are coming up with the same ideas, since a ramp is the easy kind of robot to build. You will definitely see alliances of three ramp bots, so sanddrag's comment is all the more notable - can yours climb a ramp too? Don |
#17
For the love of all that is holy, people, please don't build robots that are micrometers short of the legal footprint. Go an inch smaller in all dimensions and you'll have a happier time fitting your robot onto someone else's, should you need to do that. |
#18
Thanx for starting this thread our team 2028 was wondering about this, we're not quite sure how we're going to work this but so far have thought about letting people on us, or taking a few penalty points and setting ramps up for the other bots, it works out to be a significant amount gained. but we aren't sure
#19
Our robot would be able to climb other robots we plan on using mainly the same drive train as last year but we plan on being able to let others get on us as well. Our robot would be able to do either or. Plus our drive train is a really powerful one so we could basically man up on the other teams top scorer and take them outta the match
#20
We will be using a replica of a chassis we built in the off season.
After playing around with this chassis today, we found that it could climb a 15-20 degree slope. Keep in mind that this thing has a ground clearance of about an inch and was not designed for climbing. As to whether we will be climbing or climbed, we are not yet certain. But it is most likely that we will be focusing most of our attention on ringing. |
#21
im pretty sure that my team is planning on trying to accomplish both carrying a robot and possibly if needed, climbing on another one. we plan on using ramp method.. as far as i can tell from our last meeting...
#22
What about a 'bot that others could link onto, and then LIFT both of them?
Wouldn't that be interesting? Windwarrior Mentor-Team 17777 |
#23
what happens with this poll if your thinking that your robot will do both???
#24
I think the only real way teams are going to stack is by using a ramp system.
Not to sound too cynical or anything but lets face it I highly doubt any team is going to let another team try to pick up their robot with an arm. There's just too much that can go wrong and take them out of the competition. |
#25
There is a penalty for trying to drive on top of the opposing robots, and you can't have a ramp deployed outside of the home zone, so I don't know how well capturing would work.
#26
It is clear, as per <G56> ROBOTS in HOME ZONE - ROBOTS score bonus points at the end of the match if they are entirely in their HOME ZONE... Hence, grabbing opposite robots and lifting them won't score you points. It might also count as pinning, which would give you a penalty.
#29
What about four long pneumatic pistons that would lift the bot so another bot can drive under it. It's easier than a lifting device. The rods would be in danger though, so the cylinders could push down aluminum rods that lift the bot. Once a bot is underneith, raise the rods.
#30
| Are FIRST robots actually robots? | EHaskins | General Forum | 39 | 14-12-2006 21:40 |
| Getting good shots of FIRST robots | Billfred | Chit-Chat | 9 | 29-11-2006 08:18 |
| pic: Top Gun Top Wheels | Rick TYler | Robot Showcase | 4 | 04-02-2006 11:13 |
| Are the robots getting too heavy? | Peter Matteson | Rules/Strategy | 16 | 11-01-2006 16:36 |
| Top 10 Robots | Huskie65 | General Forum | 32 | 23-04-2003 20:14 |
