Go to Post "GP" isn't a gauge, it's a target. - Rich Kressly [more]
Unread 07-01-2007, 20:03
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
EasyC: Execute code before autonomous
Hello,
Is there a way to execute code in a loop before the autonomous mode begins? I know that the help says you can not, but our team utilizes a dashboard, and it is very helpful to be able to send back the values of certain sensors to make sure they are working properly.
Does anyone have the experience with EasyC to help me out?
-Greg
Unread 07-01-2007, 20:05
Re: EasyC: Execute code before autonomous
Maybe a loop in the initilization routine?
Unread 07-01-2007, 20:08
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Yes, just write the function you want to use and put it in intialize. It will execute any code in this function before the match starts. Check this thread out.
http://www.chiefdelphi.com/forums/sh...t=44749&page=2
Unread 07-01-2007, 20:14
So my understanding is, I need to create a while loop in Initialize that loops as long as IsAutonomous == 0 and IsEnabled == 0? That sounds like a slightly hackish solution, since WPIlib must be checking these variables to call Autonomous and OperatorControl anyway.
Unread 07-01-2007, 20:18
Kingofl337's Avatar
AKA: Adam
You only need to call isEnabled to make sure the while loop ends and you don't get stuck in initialize. Initialize is run every time you reset your robot to calibrate any sensors that may need it.
void Initialize ( void )
      while ( !IsEnabled() ) // while the robot is not enabled
            if ( GetOIDInput ( 1 , 1 ) ) // If Trigger is Pulled Go Next Auto
                  automode ++ ;
            else if ( GetOIDInput ( 1 , 2 ) ) // If Thumb is pushed go prev automode
                  automode -- ;
            SetUserDisplay ( automode ) ; // send current automode to OI display
Unread 07-01-2007, 20:23
while ( !IsEnabled() ) {
your code
Excellent. Thanks!
Unread 07-01-2007, 21:15
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
      while ( IsEnabled() ) // while the robot is not enabled
                  automode ++ ;
                  automode -- ;
Shouldn't that be:
                  automode ++ ;
                  automode -- ;
Unread 07-01-2007, 21:30
Kingofl337's Avatar
AKA: Adam
yeah forgot the ! fixed thanks.
EasyC autonomous modes TubaMorg Programming 25 12-04-2006 22:53
EasyC Default Code Team 1649 Programming 13 29-01-2006 11:52
Help!!! 979 has no autonomous day before Buckeye dddriveman Programming 11 24-03-2004 12:16
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
