Go to Post When is comes down to it, remember what FIRST is really about, it is about those students and helping to inspire them - E3 Robotics Ctr [more]
Unread 07-01-2007, 21:30
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
<G09> Dropping Tubes on Your Opponent
Hey,
I have a few questions regarding rule G09, as follows:
<G09> POSSESSION - ROBOTS may only have 1 (one) GAME PIECE in their POSSESSION at
any time during the match. Inadvertent bulldozing of GAME PIECES while the ROBOT
moves around the field is allowed. Controlled "herding" of a single GAME PIECE lying on
the floor is permitted as long as no other GAME PIECE is in the POSSESSION of the
ROBOT. Herding of multiple GAME PIECES, or herding of a GAME PIECE on the floor
while in POSSESSION of another GAME PIECE is not permitted (as this would be
considered POSSESSION of more than one GAME PIECE).
What if you were blocking an opposing robot from scoring, and they happened to drop the inner tube onto your robot while you already had one in your possession and the one they dropped on you did not roll off. Would this be considered as being "in possession" of the inner tube?
Thank you.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 07-01-2007, 21:33
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: G09 Questions
Sounds like a YMTD topic to me. I think this it would be counted as possession since the robot now has control of two ringers.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: G09 Questions
POSSESSION: a GAME PIECE is considered to be in the POSSESSION of a ROBOT if it is
being fully supported by the ROBOT, or if the ROBOT is controlling the position and movement of
the GAME PIECE. A GAME PIECE on the floor is considered to be in the POSSESSION of a ROBOT
if it contacts the ROBOT at more than a single point (e.g. the ROBOT has a concave
"plow" feature that is used to push the GAME PIECE in a controlled manner).
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 07-01-2007, 21:35
trilogism
Posts: n/a
Re: G09 Questions
So could your robot be designed to put the ringers on your opponents, who then receive penalties for possesing more than one ringer?
Edit: I know that this is against FIRST spirit
Unread 07-01-2007, 21:37
Pavan Dave's Avatar
Busy in College
Re: G09 Questions
That is against the FIRST spirit. I hope that teams do not do this but I think that I will wait until someone asks this question on the FIRST forums and we get a reply from them.
Pavan.
1745 - 118 - ΔΕΨ
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Re: G09 Questions
Originally Posted by Lostmage333 View Post
Hey,
Thank you.
Technically yes, but it should probably go to the FIRST Q&A. Obviously this is not the reason for the rule, so it's possible that they'll change it to allow for this. Designing a robot to put ringers on your opponents is legal under the current rules, but is against the spirit of the rules in my opinion.
EDIT: Sorry, didn't see that Pavan responded first.
Unread 07-01-2007, 22:44
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: G09 Questions
Is there a general rule for determining the penalty for violating a rule when it isn't explicitly given, such as <G09>? It is "not permitted", but what happens if it does? 10 points? Disable? DQ? Break the coach's kneecaps? (Please don't.) I tend to assume that things that aren't labelled as a DQ are 10-point penalties, but I don't see anything that indicates that this is the case.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 07-01-2007, 23:48
xenicator xenicator is offline
FRC #0469
xenicator will become famous soon enough
Re: G09 Questions
I seem to recall the word "innovation" prominent in the acronym of FIRST. Creativity in interpreting the rules where no robot is being harmed seems, on the contrary, to be IN the spirit of FIRST. I have noticed that Gracious Professionalism has started to be increasingly used to discourage innovation rather than maliciousness. Is it ungracious to hope that there is a slight loophole in the rules which makes this game based on technology rather than simply driver control and quickness of wit? Without these loopholes what is this game but another sporting event, something that is opposing the spirit of FIRST and promoting the “Rich and Famous” as an ideal lifestyle rather than commitment and hard work.
Unread 07-01-2007, 23:56
shamuwong's Avatar
shamuwong shamuwong is offline
pretty little words.
AKA: Mike Wong
FRC #0469 (Las Guerillas)
shamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to behold
Re: G09 Questions
Actually, the rule book specifically tells teams not to "lawyer" the rules and such. By that, they mean stick to the spirit of the competition and don't look for loopholes to get the advantage through devious game play.
I think innovation refers not to creativity in interpreting the rules, but rather, the game.
ΜOΛΩΝ ΛΑΒΕ!
attending: great lakes regional, west michigan regional, detroit regional, the championship
Last edited by shamuwong : 08-01-2007 at 00:09. Reason: sentence didn't make sense.
Unread 08-01-2007, 00:00
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
Re: G09 Questions
Looking at the situation from a Ref aspect, I would think that they would come out with a revision to this that states that if a robot inadvertently comes into possession of multiple ringers (i.e. by means of an opposing robot dropping a ringer onto it), that if it does not try to loose possession of the ringers and reduce its possession to one ringer in a timely fashion (i.e. within 5 seconds), the offending robot will be assessed a multiple possession penalty (not sure if there is already one, but if there isn't my guess is that it would be another 10 point penalty).
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
Unread 08-01-2007, 00:04
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Re: G09 Questions
That's "inspiration".
Getting ahead on loopholes is a part of today's corporate culture, and is something that I would not expect FIRST seeking to encourage. If you find a loophole, go ahead and put in on the Q&A, and see if it's something that's allowed.
_
Unread 08-01-2007, 00:28
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: G09 Questions
reading the rule, notice the mention of "controlled" in the rule; i suspect that this will be how the define 'being in the possession' of a game peice, and while there may be grey area on that, i confident that an opponents game peice that is dropped onto your 'bot by an opposing machine wouldn't fulfill this requirement, and thus wouldn't be considered 'in your possession'.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 08-01-2007, 00:33
Brandon Holley's Avatar
Re: G09 Questions
Here is another possiblity, maybe a YMTC deal......your robot is in possession of a tube and is attempting to score it on teh rack. As you are doing this the tube hits the spider foot and slips over your arm and slides down to ur base (the tube is now around your arm)....there is still 1:30 left in the match...is your bot done with tubes for the match???
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 08-01-2007, 02:12
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Re: G09 Questions
Different question, same thread:
Am I blind, or is there not a penalty for violating G09 (yet)? 10 pts? DQ?
If not, FIRST will probably catch this in a revision pretty soon (crosses fingers).
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 08-01-2007, 02:21
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Re: G09 Questions
Yeah, you're not the only one who doesn't see it in there. I'm expecting a clarification too. (And I'm hoping it's not the kneecap thing.)
_
Sitting on top of tubes notquitehere188 Rules/Strategy 23 08-01-2007 02:03
S.O.A.P (SigmaC@t Opponent Analysis Program) Arefin Bari General Forum 27 11-12-2005 14:13
Dropping a Regional w_b305 Regional Competitions 1 13-01-2005 09:51
dropping balls Joe Ross Math and Science 18 25-08-2004 22:40
Scoring when an opponent is in contact with your tallest stack. Randy Ai Rules/Strategy 1 06-01-2003 17:17
