Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-01-2007, 18:24
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is online now
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Vacuum tube.
Did anybody have a use for the vacuum tube in the kit of parts? Maybe they expect us to suck other robots closer to us to aid in defense?
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 07-01-2007, 18:26
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Re: Vacuum tube.
Its to grasp the inner tubes.
Unread 07-01-2007, 19:58
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Re: Vacuum tube.
I agree with Matt. I think that the vaccum tube should maybe be hooked up to a lightweight low power using vaccum to create suction between the grasper of the ringer and the ringer.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 07-01-2007, 20:58
AChastain's Avatar
AChastain AChastain is offline
FRC #0234 (Cyber Blue)
AChastain will become famous soon enoughAChastain will become famous soon enough
Re: Vacuum tube.
I don't know about that. Personally, I couldn't wait to try it out on a tube but I don't think that it would hold it very effectively now that I have seen them together. Hey, I'm no expert though.
"Thirty bucks says the blue guy wins."
"You On!"
- bystanders, MEGAS XLR
Unread 07-01-2007, 21:19
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: Vacuum tube.
I dont think they expect us to try to suck other robots to ourselves...
It seems as if it could be used to assist in the picking up of the inner tubes. I don't see how it can be applied in any other way.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 07-01-2007, 21:53
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Vacuum tube.
They give you something to create a vaccuum...try that!
Unread 07-01-2007, 22:04
Flanamana's Avatar
Flanamana Flanamana is offline
Team Captain
FRC #1991 (Dragons)
Team Role: Driver
Flanamana is an unknown quantity at this point
Re: Vacuum tube.
I agree with Matt. I also think that they're going to try to reinforce the idea of using a vaccuum instead of maybe a hook, so there's not such a thret of popping the innertubes
Unread 07-01-2007, 22:09
Dianna Bartone
Posts: n/a
Re: Vacuum tube.
Or they want to cut back on time spent cleaning up after the competition. Robo-slaves.
Unread 07-01-2007, 22:22
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
Re: Vacuum tube.
our team hooked up the vacuum the first day to try it out. it had an Ok grip on the tube, enough that the vacuum on the end of a manipulator could manuveur the tube effectively. there were two drawback to it that we noticed. one, the angle of the suction cup provided made it so that the cup has to be pressed against the tube hard to get it to seal. also, one the suction is cut off to drop the tube, it tends to stick, and needs some forcefull shaking to come off. i dont think we will be going with a vacuum this year...
on this note though, i remmeber the first time i experianced FRC. i was in 8th grade, and was shadowing at the specialty high school for engineering in my county (i eneded up not goin there). i stayed after for the robotics meeting (2004 challenge) and saw them working with suction. the team was trying to get a vacuum going strong enough to lift the big exercise balls. they couldnt get it to work. anyway just thought i would share that.
dont take my word for it though, try out the vacuum yourself and see if you can get it to work nicely. we are all creative people and there is more than one way to skin a cat
Unread 07-01-2007, 22:39
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Re: Vacuum tube.
lmao... who noes.. maybe you'll get extra points for cleaning the field this year
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 13-01-2007, 13:55
Benyamene's Avatar
Benyamene Benyamene is offline
FRC #2168 (Cyber Falcon)
Team Role: Student
Benyamene is an unknown quantity at this point
Re: Vacuum tube.
How did you hook up the vacuum?
Unread 13-01-2007, 14:04
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Vacuum tube.
OMG!
Awesome strategy!
Imagine these scenarios:
You lift a robot with the power of air for the points.
Latch onto one's side panel and trail it the whole match playing defense and just getting all over them so they can't score if they are really good..
How funny would that be?
Vacuum Forming Machine sanddrag Technical Discussion 4 06-12-2005 19:10
Vacuum Generator Peter Matteson Pneumatics 0 04-02-2005 15:58
Vacuum Generator Peter Matteson Technical Discussion 0 04-02-2005 15:58
Vacuum NoRemorse Rules/Strategy 25 22-01-2004 12:34
Vacuum nwagers Pneumatics 16 31-10-2003 15:57
