Go to Post A winning robot is not a winning robot unless you have winning drivers too. You need the time to develop both. - Jim Zondag [more]
Unread 06-01-2007, 18:05
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Banebot Gearbox
We tried to take the metal plate off like your supposed to but couldnt get them off. Anyone know what size we need. Nothing we had worked and the ones that looked like they fit just would slip. They seem to be in there very tight.
Unread 06-01-2007, 18:57
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: Banebot Gearbox
FYI the allen screws are English I don't remember the size but I assembled them not to long ago
Unread 06-01-2007, 19:40
Happy Birthday! Nick 568 Nick 568 is offline
FRC #0568 (The Nerds of The North)
Nick 568 is on a distinguished road
Send a message via AIM to Nick 568 Send a message via MSN to Nick 568 Send a message via Yahoo to Nick 568
Re: Banebot Gearbox
I'm not meaning to hi-jack this thread, but has anyone else had problems with their gearbox jamming? One of the boxes is fine, but the other ones keeps jamming up. We have taken it apart and re-assembled it numerous times to no avail.
P.S. the allen wrench size is: 3/32" for the plate.
Unread 06-01-2007, 19:45
Team 2021 Captain
AKA: Chris Davidson
Re: Banebot Gearbox
Much appreciated. If i can figure out where we put our allen wrenches ill let you know if ours jam. Maybe put some grease on em.
Unread 06-01-2007, 19:47
Re: Banebot Gearbox
Thanks, we've added more grease, but still nothing. I look forward to your response though!
UPDATE: We figured out what the problem was, apparently, the bushing was too long on one of the motors, so we ground it down on the lathe and all is well!
Unread 07-01-2007, 14:02
Team 2021 Captain
AKA: Chris Davidson
Re: Banebot Gearbox
Using 3/32" only works for half of them for us. The others use something large than that but its smaller than the 1/8" wrench. Its so annoying. Im going to have to see if I have a 7/64" wrench or figure out what the heck is wrong with these screws.
Unread 07-01-2007, 14:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Banebot Gearbox
Has anyone pulled one apart? Is there only that one bearing I can see from the outside? I'm guessing it wouldn't be wise to slap a wheel smack on there without another bearing eh?
Unread 07-01-2007, 15:27
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Banebot Gearbox
I haven't pulled apart the gearbox yet, but I was wondering the same thing. Dr Joe, care to give an answer to this?
While picking up the KOP at the Manchester Kickoff, I noticed that FIRST had built a couple practice bots. One robot used the new Banebot Trannies, and left the drive shaft fully cantilevered. Below you can find a picture. I was quite surprised to see if used in this configuration.
I don't think I'll be using it in this configuration, but YMMV.
BEN
Unread 07-01-2007, 15:50
Gdeaver Gdeaver is offline
FRC #1640
Re: Banebot Gearbox
I too have concerns about shaft loading on the BB trans. If we were to use the 2 cim adapter and use 2 sprockets to duplicate last years 4 motor 4 wheel drive kit bot, can the 56mm trans take that shaft load and input? Has it been tested. Is the bearing support necessary for a 2 sprocket load? Can the 56 mm trans handle 2 cims? Would a safer bet be 4 cims 4 trans? Joe any comments?
Unread 07-01-2007, 20:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Banebot Gearbox
I hate cantilevered loads. But I learn to live with them if their is good support for the shaft and if the loads are not too great.
So... ...my first recommendation is that you figure out a way to support the end of the shaft if you can. In fact, I recommended that FIRST put the bearing plate in the kit.
But...
There ARE two bearings supporting the output shaft but the bearings are side by side so things are kind of in a gray area. Yes I think is okay to have some side load on these shafts, but I would not suggest teams cantilevering load if the sprocket or gear is going to be far out on the shaft.
You can probably get away with it is you have a single sprocket and are not using the encoder (which spaces the load out).
Joe J.
Team #88, TJ2
Unread 07-01-2007, 22:11
Team 2021 Captain
AKA: Chris Davidson
Re: Banebot Gearbox
Thank you for your reply but can you answer why a 3/32" allen srench only works on half my screws? As of right now my only solution is to cut them out and buy and replace them with new ones from BB.
Unread 07-01-2007, 22:15
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Banebot Gearbox
I don't have an answer. Have you tried a metric hex wrench? It seems unlikely, but I suppose it is possible that a few metric screws got mixed in the bin where ever BB has them assembled?
Anyone else having this issue?
Very odd.
Joe J.
Team #88, TJ2
Unread 07-01-2007, 22:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Banebot Gearbox
are you using a VEX allen wrench? they're not quite up to spec....and will strip out a screw that is really tight.
Unread 08-01-2007, 11:43
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Banebot Gearbox 2.5mm metric hex wrench required
See this thread:
http://www.chiefdelphi.com/forums/showthread.php?t=51250
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 08-01-2007, 13:15
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Banebot Gearbox
All of the Banebots screws are metric (I had fun taking it apart), and if you dont use metric then you will strip the socket heads.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Kit GearBox Talha Kit & Additional Hardware 2 10-01-2006 21:30
Gearbox Lord Nerdlinger Motors 20 15-07-2003 00:38
Gearbox ZACH P. Motors 4 09-02-2003 20:14
GearBox Working Balbinot General Forum 2 08-01-2003 22:12
