Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
Unread 07-01-2007, 23:10
Seki's Avatar
Seki Seki is offline
Hamster Hands
AKA: Tina
FRC #2604 (Metal and Soul)
Seki is an unknown quantity at this point
Send a message via MSN to Seki
MK 12 volt battery question
They said that we could ONLY use the MK 12 volt battery as our maing power battery, aren't they the same as last years batteries? the previous years batteries are 12 volt, can we still use them?
anyone know?
-Thanks
Unread 07-01-2007, 23:13
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: MK 12 volt battery question
The batteries are slightly different from those last year. I'm not sure of exact specs. You are not aloud to use batteries from last year as this would create an unfair advantage to those teams who dont have those batteries from last year
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
anyone know?
-Thanks
It is not the voltage of the battery that is different. It is the model number. If you would go look at your batteries from previous years you would notice the are exide ES-xxx* model number. EX-xxx* != MK 12
-John
*I do not know the exact model number off hand.
Unread 07-01-2007, 23:35
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Specs for the 2007 battery are here.
Specs for the 2006 battery are here.
The new one appears to have about 10% less stated capacity at 1C discharge rate. So if you could use the older battery you might get an advantage over a team using the new one -- which is almost certainly the reason why the older ones are not allowed this year. For more, see this post.
Richard Wallace
since 2003
Unread 07-01-2007, 23:39
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
And it is definetly fair to all of a sudden make the batteries from previous years extinct in order to make the teams who collected their batteries from previous years and who can't afford to buy 10 extra batteries like other teams go through all the trouble of possibly losing qaulifiers due to the fact that the batteries don't charge fast enough.
Sadly there's nothing we can do about that. Might as well learn to deal with it. Big disappointment but oh well.
Unread 07-01-2007, 23:50
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Not every team is going to be in a match at the same time. We do know how to share.
Unread 08-01-2007, 00:02
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Everyone's in the same boat. Everyone has only 2 batteries and no collected batteries from previous years. That is, in fact, MORE fair than everyone but rookies having a collection of batteries from prior years. You can still use old batteries for testing and practice day. You have more chargers than the rookies. With even a little bit of effort on your part to solving the problem you could make 2 batteries work just fine for a regional. If you buy just one extra battery you should be more than covered. They can be had for around $50.
I speak from experience by the way. 57 takes just 3 batteries anywhere we travel and we don't have any problems.
Unread 08-01-2007, 00:09
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
One of the bullets in <R46> says:
Originally Posted by 2007 FRC Manual
Items specifically PROHIBITED from use include: Batteries different from, or in addition to, those provided in the Kit Of Parts.
I interperet that to say that we can only use the 2 batteries provided in the kit. Opinions?
Unread 08-01-2007, 00:13
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
If that is FIRST's intention, I don't think it could be enforced. (How would FIRST know if a team brought more than two batteries to the regional?)
That said, I wonder if that is a mistake in the manual.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
That rule was the same last year as well. You will be able to buy more of the same battery and use them, as long as they are the same as the ones in the KOP.
Expect a clarification in the Q&A or a Team Update.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 08-01-2007, 00:15
robind robind is offline
FRC #0675
robind is an unknown quantity at this point
No. I would interpret that to mean we can't use a battery in the kit, and another battery not in the kit at the same time on the robot.
Unread 08-01-2007, 00:18
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
I would interpret this:
<R53> The only legal main source of electrical energy on the ROBOT during the competition is the
12VDC non-spillable lead acid battery provided in the 2007 Kit Of Parts. That 12V battery is
the MK Battery, ES17-12. Additional batteries may be purchased through a local MK
Battery supplier.
To mean that we can purchase additional batteries, and therefore, use them in competition, as long as they are MK ES17-12s.
-Nate
Unread 08-01-2007, 00:36
Agreed. R46 covers what you can use ON the robot at any time. No using 2 batteries at once, no using a different battery on the robot. Doesn't cover what you can have at the comp. So I would expect some Q&As but no updates on that.
Unread 08-01-2007, 00:48
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Don't know if anyone has noticed this, but the new batteries seem a bit heavier as well. We pulled out the scale today and clocked them at about 13.5lbs, which is about 1.5 lbs more than the old batteries (someone correct me if I'm wrong that the old ones weighed 12lbs)
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 08-01-2007, 01:48
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Richard,
There are some major differences between the two sections of spec sheets you posted.
Originally Posted by ES17-12 Spec Sheet, Top Section
Maximum discharge current (A) 5 sec: 90
Originally Posted by ES17-12 Spec Sheet, Bottom Section
Maximum Discharge Current for 5 seconds: 720 A
That's a huge difference. The Exide battery from 2006 had a 230A max discharge. Can anyone confirm which of these is right? Am I missing something here? If the max discharge has dropped all the way to 90A, we'll definitely be reconsidering our motor usage.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Battery question CraigHickman Electrical 9 23-10-2006 21:55
Extra Battery Question 1337pcgamer General Forum 1 16-02-2006 19:58
Question regarding to Battery Packaging sxlterps General Forum 1 19-02-2005 17:37
7.2 Volt Battery Justin_302 Electrical 4 28-01-2005 23:25
Help!!! Battery question trollin1st General Forum 7 12-02-2003 08:48
