Go to Post If this doesn't show up in spotlight at some point I'm almost going to be sad. - Andrew Schreiber [more]
Unread 07-01-2007, 23:37
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Backup Battery life and the CMUCam
Does anyone have a definative reference for how the "backup power" circuit runs through the RC unit to the perhiperal devices (PWM, RELAY etc.)?
The "standard description" of how this works seems to be that the 7.2v battery is used to deal with sags in the main 12V supply, but that doesn't seem to be the case.
I've noticed that when I power the CMUCam off a PWM output (as recommended), after a moderate time of camera testing (with no other major loads) the camera stops communicating until I replace the backup battery with a fresh one.
I would have expected the RC to be powered by either the 12V or the 7.2V via diodes. So if the 12V is good, the 7.2V battery won't get drained... but that does not seem to be the case.
Unless this is just a matter of me using an incorrect output to power the camera, this is pretty annoying, since the rules don't seem to permit me to substitue the old-style AA NiCds with NiMH barteries that would give me better camera life.
I'm just trying to find a reliable way to ensure that the camera keeps running as long as the RC runs.
Is there a better "legal" way to power the camera? maybe run the camera off the 12V supply directly. Is it just as simple as me installing my own 5V regulator?
I know... a lot of questions.....
Phil Malone
http://www.GEARSinc.org
backup battery nirty Electrical 1 08-02-2006 14:40
Powering the cam without a backup battery Uberbots Programming 11 27-01-2006 10:00
charging backup battery Max Lobovsky Electrical 6 12-03-2004 10:24
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Backup battery and IR Matthew_H Electrical 6 21-01-2004 22:13
