Go to Post As a programmer, I am trying to use more 0's than 1's to save weight. - Jared Russell [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-01-2007, 23:45
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
Unhappy 07 Kit Wheel Bearings Dilemma
So we got our kit, put 2 of the 8 bearings in each supplied wheel, and found that none of the 3 aluminum rods fit inside of the bearings... Did we do something wrong? What did everyone else do?
Unread 07-01-2007, 23:48
clydefrog88's Avatar
clydefrog88 clydefrog88 is offline
FRC #4087 (Falcon Robotics)
clydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the rough
Re: 07 Kit Wheel Bearings Dilemma
we were tinkering with our kitbot today and we found the same problem.
of course, i read no assembly instructions so i might have done something wrong. even so, the other bearings in the KOP didn't even fit into the wheels.
Unread 07-01-2007, 23:56
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
You're not the only ones. We found the bearings didn't fit standard 1/2" steel rod. Anyone have the bearing and a dial caliper handy?
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 08-01-2007, 00:09
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
those aluminum rods are (most likely) meant to be used with the IGUS parts, and as such may not be exactly 1/2". While the info on the AndyMark.biz sitesuggests that the ID of those bearings is 1/2", in past years the wheel bearings have been either 3/8" or 5/16".
<edit> according to the KOP checklist, the bearings a 3/8" ID </edit>
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 08-01-2007, 00:14
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
when we came accross that problem today, we simply put on the wheels from 2006...
Unread 08-01-2007, 00:22
Brandon Holley's Avatar
I had the kit bot together today in about half an hour, i went to grab the wheels and get those on and ran into this kinda problem......My solution: I took a piece of precision grounded 1/2" steel shaft, measured it, and then measured the ID of the bearings, they were exactly the same size.....It takes some effort to get em in the bearing holes, but they do eventually get in there.
Another problem that comes up is that the bearing are 1/2" ID and the holes that you would run the shafts through on the frame are 3/8", so obviously you have to fix this problem....A. If you are planning using the kit bot as your robot, I would turn down the ends and then assemble each side and put the bot together or B. What we're doing since were using this as a test bot, just drill out the holes to 1/2" and collar the shaft and wheels in place.
Let me know if anyone else comes up with solutions to these problems.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 08-01-2007, 00:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
like finding a piece of 1/2" od, 3/8" id metal tubing and some 3/8" bolts?
Unread 08-01-2007, 00:27
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The bearings are 1/2" ID, not 3/8". So no, they aren't going to fit any rod in the kit. As far as "standard" 1/2" rod.... The rod is almost certainly going to have a +/- .001 tolerance. Maybe a -.005 tolerance. At any rate, the inner race of the bearing is going to also be something like -.0003 tolerance. So, mostly, your shaft is too big and the hole is too small. Ideally, you sand your shaft until the bearing slides on smoothly.
Unread 08-01-2007, 00:29
If you have that laying around go for it, we didnt, drilling those holes bigger took about 2 minutes total
Unread 08-01-2007, 00:31
Christian Christian is offline
FRC #0408 (RoboTicks)
Christian will become famous soon enoughChristian will become famous soon enough
Send a message via AIM to Christian
I came across this yesterday and tried to wrap my head around the problem. I thought our KOP was missing something, but after going through the checklist again, it wasn't. Someone wasn't thinking when they decided to switch to the AndyMark wheels with 1/2" bearings while keeping the 3/8" kit chassis. I just made a quick trip to Home Depot and picked up some 3/8" ID x 1/2" OD aluminum tube (and bolts, wires, and the sort). It slips over the 3/8" bolts and works well with the bearings.
President/Programming/Mechanical/Electrical/Animation/Website
robots and cake are all you need, everything else like oxygen are considered bonuses.
Unread 16-01-2007, 19:06
obso1337 obso1337 is offline
Funky Monkey Robotics President
AKA: Chris Towler
FRC #2032 (Funky Monkey's)
obso1337 is an unknown quantity at this point
Same here, we just bought 1/2 inch rod to support the bearing size
Unread 16-01-2007, 22:02
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Hmmm...I didnt even look at them yet. This is obviously going to be a problem with our chassis, seeing as it will have a 1/2" oblong hole for chain tension.
I also wasn't going to be using 1/2" shaft, I was just gonna throw a 1/2" bolt through the oblong holes and wheels so the wheels can be quickly adjusted for chain tension. I'll be making sure 1/2" bolts fit through first thing tomorrow....
Also if you are using shaft, you could always turn it down a bit on a lathe to make it a better fit.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 16-01-2007, 23:03
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
We'll be using 1/2 shoulder screws as axles, which have a -.002 to -.004 dia tolerance on the shoulder, with a 3/8-16 thread on the end.
If you're interested in finding out more about these parts, you can go to www.McMaster.com and type "shoulder screw" into the search.
Hope that helps.
Scott5736 (formerly Scott3137(formerly Scott358))
Fundraising dilemma Temp Fundraising 13 20-03-2006 10:39
Scouting and the Prisoner's Dilemma Leav General Forum 5 03-03-2005 12:17
Push bearings that come in kit Adam Y. Technical Discussion 1 18-01-2003 10:13
FIRST 2002: Prisoner's Dilemma archiver 2001 1 24-06-2002 04:00
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
